Plugins 〉Destiny Datasource
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Destiny Datasource
- Overview
- Installation
- Change log
- Related content
Destiny Data source
Fetches activity history for players from Destiny 2 using the Bungie.net API.
- Lists activity history for single player.
- Can return history for all characters, or specific characters
- Can filter activity history by activity mode
Data returned for each activity:
- Character played
- Activity details (activity name, PvP map, and 'directory activity')
- Specific activity (e.g. map for PvP)
- Start and end times, and activity duration
- Time character was in the activity (e.g. if joined in progress)
- PGCR ID
- Whether activity was successfully completed or not
- Whether character won or lost
Setup
This data source plugin requires a developer API key from Bungie.net:
- Log into bungie.net
- Visit www.bungie.net/en/Application/Create
- Fill in the fields. It's not particuarly important for most of the values:
- Application Name: a familiar name for you to refer to this API key
- Website: Doesn't matter - example.com is fine
- OAuth Client Type: "Not applicable"
- Redirect URL: leave blank
- Origin Header: leave blank
- Once created, the page will list the API Key. Copy and use this when configuring this Data source in Grafana.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Destiny Datasource on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Destiny Datasource from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
