Plugins 〉Pareto Chart
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Pareto Chart
- Overview
- Installation
- Related content
Grafana Pareto Panel Plugin
This plugin provides you the ability to draw a Pareto chart with RDB
and TimeSeries databases
Features
- Setting a custom background color to the tooltip overlay
- Configurable vital few and trivial many lines
- Pan and zoom for detailed info without changing date range
- Set decimals count on displayed values
- Specify bar spacing
- Quickly copy bar data to clipboard simply by clicking on the bar
- Option to show/hide bar values on default
- Style graphs to need
TimeSeries (InfluxDB) dashboard impression
MySQL Example
Provide the defects
which could be "categories" (type string) for example and a frequency
value cummulatives/counts (type number).
| Defects | Counts | | :-: | :-: | | Error 1 | 10 | | Error 2 | 4 | | Error 3 | 1 | | ... | ... |
Example Query
SELECT _label_, _count_, ...
FROM _table_
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Pareto Chart on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Pareto Chart from the commandline:
grafana-cli plugins install
