Plugins 〉Vercel
Developer
Grafana
Data Source
grafana
Enterprise
Vercel
Documentation →
Grafana Vercel data source plugin
The Vercel data source plugin for Grafana allows you to query and visualize data from Vercel in Grafana.
Project status
NOTE: This plugin is in public preview. Refer Grafana Labs release life cycle documentation for further details. If you notice any issues or having feature request, create a support ticket with your Grafana Enterprise support channel.
See also
Installing Vercel on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Vercel from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v0.1.1-preview - 2025-02-10
  • ⚙️ Chore: Update backend dependencies
0.1.0-preview - 2024-08-08
Initial release.
  • 🚀 Feature: Initial Release
