Plugins 〉PagerDuty
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
PagerDuty
- Overview
- Installation
- Change log
- Related content
- Documentation →
Grafana PagerDuty data source plugin
The PagerDuty data source plugin allows you to query incidents data or visualize incidents within Grafana using annotations.
See also
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing PagerDuty on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install PagerDuty from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v1.2.2 - 2025-02-11
- ⚙️ Chore: Update backend dependencies
v1.2.1 - 2025-02-04
- ⚙️ Chore: Update frontend dependencies
v1.2.0 - 2025-01-28
- 🚀 Feature: Add support for PDC
v1.1.10 - 2025-01-10
v1.1.9 - 2024-12-18
v1.1.8 - 2024-12-16
v1.1.7 - 2024-11-15
- ⚙️ Chore: Improve accessibility of config editor and query editor
v1.1.6 - 2024-11-12
- ⚙️ Chore: Updated backend dependencies
v1.1.5 - 2024-10-23
- ⚙️ Chore: Improve logging
v1.1.4 - 2024-10-03
- ⚙️ Chore: Minimal supported Grafana version is now
10.4.8
v1.1.3 - 2024-09-23
v1.1.2 - 2024-08-30
- ⚙️ Chore: update backend dependencies
v1.1.1 - 2024-07-18
- ⚙️ Chore: Capture error source
v1.1.0 - 2024-07-11
- ⚙️ Chore: Added SLO metrics to the plugin
v1.0.0 - 2024-07-10
- ⚙️ Chore: Stable release:
1.0.0
- ⚙️ Chore: Update dependencies
v0.2.1 - 2024-06-19
v0.2.1-preview - 2024-05-31
v0.2.0-preview - 2024-03-22
- 🐛 Fix: Fix crash on malformed query and bump dependencies
v0.1.4-preview - 2024-03-18
- 📝 Documentation: Update documentation
v0.1.3-preview - 2024-03-13
- ⚙️ Chore: Backend binaries are now compiled with Go version
1.22.1
v0.1.2-preview - 2024-02-15
v0.1.1-preview - 2024-02-14
0.1.0-preview - 2024-02-14
- 🚀 Feature Initial preview release
