Plugins 〉Falcon LogScale
Developer
Grafana Labs
Data Source
grafana
Falcon LogScale
Documentation →
Falcon LogScale data source for Grafana
The CrowdStrike Falcon LogScale data source plugin allows you to query and visualize Falcon LogScale data from within Grafana.
See also
Technical documentation
License
Installing Falcon LogScale on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Falcon LogScale from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.8.1
  • Any field can be used for query template variables #488
  • Bug: Correctly set format as logs flag in Explore by default. #492
  • Bug: Correct X-Id-Token when fetching repos. #489
1.8.0
1.7.6
  • Dependency updates.
1.7.5
1.7.4
  • PDC support.
1.7.3
1.7.2
  • Add errorsource #380
1.7.1
1.7.0
  • Feature: Upgrade VariableEditor to remove usage of deprecated APIs and add repository variable query type. #303
1.6.0
  • Fix: State bug in VariableEditor
1.5.0
  • Experimental: Support OAuth token forwarding for authentication. See here for further details.
1.4.1
  • Prepend @timestamp field to ensure it is always used as the timestamp value in the logs visualization.
1.4.0
  • Add $defaultRepo option to Repository dropdown.
  • Other minor dependency updates
1.3.1
  • Error message is more descriptive when a repository has not been selected.
1.3.0
  • Bump github.com/grafana/grafana-plugin-sdk-go from 0.180.0 to 0.195.0
1.2.0
  • Bug: Issue where users were unable to select default repository is fixed.
1.1.0
  • Minimum Grafana required version is now 9.5.0
  • Logs in explore view can be filtered by a value or filtered out by a value.
  • The settings UI has been overhauled to use the new Grafana form and authentication components.
1.0.1
  • Bug: TLS option are now correctly passed to the LogScale client.
1.0.0
  • Documentation
  • A default repository can be selected in the data source config.
  • Support added for abstract queries.
  • Fields are ordered according to meta-data response from LogScale. '@rawString' is always the first field.
  • Log view is the default option in Explore.
  • Grafana data frames are converted to wide format when using a LogScale group by function to support multiline time series.
  • Bug: Data links do not throw an error if there is not a matching log.
0.1.0 (Unreleased)
  • Data links from LogScale logs to traces
  • Bug: Remove unused auth options
  • Bug: DataFrame types will be correctly converted when the first field is nil
0.0.0 (Unreleased)
Initial release.
