Plugins 〉grafana-echo-datasource
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
grafana
  • Overview
  • Installation
  • Related content
Installing grafana-echo-datasource on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install grafana-echo-datasource from the commandline:
grafana-cli plugins install
2. Configure the Data Source
