Plugins 〉Dynatrace
Developer
Grafana Labs
Data Source
grafana
Enterprise
Dynatrace
Documentation →
Instantly visualize Dynatrace data in Grafana
The Dynatrace data source plugin is the easiest way to pull Dynatrace data directly into Grafana dashboards.
  • Visualize it either in isolation (one database) or blend it with other data sources.
  • Discover correlations and covariances across all your data in minutes.
Installing Dynatrace on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Dynatrace from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
v3.21.10 - 2025-03-10
  • 🐛 Fix: Fix pagesize error on problems V2 with fields
v3.21.9 - 2025-02-19
  • ⚙️ Chore: Update frontend dependencies
v3.21.8 - 2025-02-17
  • ⚙️ Chore: Improve error logging
v3.21.7 - 2025-02-11
  • ⚙️ Chore: Update backend dependencies
v3.21.6 - 2025-02-04
v3.21.5 - 2025-01-29
  • 📝 Documentation: fix links to Dynatrace documentation
v3.21.4 - 2025-01-10
v3.21.3 - 2025-01-09
  • ⚙️ Chore: backend dependencies compiled with latest go version
v3.21.2 - 2024-12-18
v3.21.1 - 2024-12-16
v3.21.0 - 2024-11-29
  • 🚀 Feature: Add Timeout configuration for Http client to UI
v3.20.0 - 2024-11-28
  • ⚙️ Chore: Bump backend dependencies
v3.19.7 - 2024-11-25
  • ⚙️ Chore: Fix error source for loading cache errors
v3.19.6 - 2024-11-22
  • ⚙️ Chore: Improve error handling
v3.19.5 - 2024-11-21
v3.19.4 - 2024-11-20
  • 🐛 Chore: Improve error handling
v3.19.3 - 2024-11-12
  • ⚙️ Chore: Updated backend dependencies
v3.19.2 - 2024-10-30
  • ⚙️ Chore: migrate config editor page to use @grafana/ui components
v3.19.1 - 2024-10-29
  • 🐛 Fix: Fill null value when timeseries data is missing
v3.19.0 - 2024-10-28
  • 🐛 Fix: Move query cache for Metric Dimensions onto Datasource instance from global scope
v3.18.7 - 2024-10-03
  • ⚙️ Chore: Minimal supported Grafana version is now 10.4.8
v3.18.6 - 2024-09-23
v3.18.5 - 2024-09-06
  • 🐛 Fix: Fix error when management zone is not filled in
v3.18.4 - 2024-08-30
  • ⚙️ Chore: update backend dependencies
v3.18.3 - 2024-08-23
  • 🐛 Fix: Fix query options in alert setting
v3.18.2 - 2024-08-16
  • 🐛 Fix: Fix timeout issue in healthcheck in config page
v3.18.1 - 2024-08-02
  • 🐛 Fix: Support dashboard variable in metrics query in code mode
v3.18.0 - 2024-07-10
  • 🐛 Fix: Fix supporting variables in management zones
v3.17.0 - 2024-06-27
  • ⚙️ Chore: Added SLO metrics to the plugin
v3.16.0 - 2024-06-27
  • 🚀 Feature: Support dashboard variable in management zone select
v3.15.0 - 2024-06-27
  • 🚀 Feature: Support management zone both in builder and code mode for Metric Query
v3.14.8 - 2024-06-24
  • 🚀 Feature: Support Alias in code mode in Metric Query
v3.14.7 - 2024-06-21
  • ⚙️ Chore: update sdk license check
v3.14.6 - 2024-06-20
  • 🐛 Fix: fix pagination
v3.14.5 - 2024-06-18
  • 🚀 Feature: Support Problems V2, Events, Synthetic, Tokens Queries
v3.14.4 - 2024-06-13
  • 🚀 Feature: Support SLO API query
v3.14.3 - 2024-06-06
  • ⚙️ Chore: update dependencies
v3.14.2 - 2024-05-22
  • 🚀 Feature: Support Nullable in Parse Individual Fields in Direct API Query
v3.14.1 - 2024-03-13
  • ⚙️ Chore: Backend binaries are now compiled with Go version 1.22.1
v3.14.0 - 2024-03-01
v3.13.0 - 2024-02-27
  • ⚙️ Chore: Add error source for returned responses
v3.12.1 - 2023-11-23
  • 🐛 Fix: fixes an issue when querying data in safari
v3.12.0 - 2023-11-09
  • ⚙️ Chore: Update backend and frontend dependencies
  • ⚙️ Chore: Minimal supported Grafana version is now 9.5.13
v3.11.3 - 2023-09-13
  • 🐛 Fix: use labels in code editor mode in variable editor
v3.11.2 - 2023-09-12
  • ⚙️ Chore: migrate to create-plugin
v3.11.1 - 2023-08-11
  • 🐛 Fix: fix annotation editor for query type - problem
v3.11.0 - 2023-07-19
  • 🚀 Variable editor Added support for text and value pair when raw url query type used in variable editor query
  • ⚙️ Chore Grafana enterprise SDK updated to latest
v3.10.2 - 2023-06-08
  • ⚙️ Chore: backend libs updated with golang:1.20.5
v3.10.1 - 2023-06-01
  • ⚙️ Chore: update plugin sdk go version
v3.10.0 - 2023-05-10
v3.9.2 - 2023-05-03
  • ⚙️ Chore: Backend binaries are now compiled with golang 1.20.4
v3.9.1 - 2023-04-19
  • ⚙️ Chore: Backend binaries are now compiled with golang 1.20.3
v3.9.0 - 2023-02-28
  • ⚙️ Chore: Removed legacy AngularJS dependencies
  • ⚙️ Chore: Backend binaries are now compiled with Go 1.19.6
v3.8.1 - 2022-02-16
  • 🐛 Fix: Alias tooltip hanging/blocking
v3.8.0 - 2022-01-10
  • 🚀 Feature: (Enhancement) Faster Metric Selector using less memory
v3.7.2 - 2022-12-02
  • 🐛 Fix: Apply Management zone filter on Entity query
v3.7.1 - 2022-12-13
  • ⚙️ Chore: Backend binaries are now compiled with Go 1.19.4
  • ⚙️ Chore: Grafana enterprise SDK updated to latest to fix licensing issues
  • ⚙️ Chore: Grafana backend plugin SDK updated to v0.145.0
  • ⚙️ Chore: Backend third party dependencies updated
v3.7.0 - 2022-12-02
  • 🚀 Feature: Management zone filter on Metrics query
v3.6.0 - 2022-12-02
  • 🚀 Feature: Added management zone queries
v3.5.5 - 2022-11-25
  • 🐛 Fix: Fixed a bug in variable queries where results weren't showing when using direct api access query type
v3.5.4 - 2022-11-03
  • ⚙️ Chore: Backend binaries compiled with latest go version 1.19.3
v3.5.3 - 2022-10-25
  • 🐛 Fix: Fixed an issue where the direct API access in variable results produce inconsistent results.
  • ⚙️ Chore: Backend binaries compiled with latest go version 1.19.2
v3.5.2 - 2022-09-20
  • 🐛 Fix: Fixed a bug where direct api access throws error when response contains null value
  • 🐛 Fix: Fixed a bug where query editor doesn't show query when using metrics raw query
  • 🐛 Fix: Fixed a bug where dynatrace alerting throws coarser resolution error due to incorrect interval resolution
v3.5.1 - 2022-09-16
  • 🐛 Fix: Fixed an issue with the json editor in the query editor for direct api access
v3.5.0 - 2022-09-06
  • 🚀 Feature: Support for querying Logs from DynaTrace (beta)
  • 🚀 Feature: Support for querying Audit Logs
  • 🚀 Feature: Addition of variable query editor
v3.4.4 - 2022-07-28
  • Made alias templating fully configurable with template variables in the metric builder editor
v3.4.3 - 2022-07-08
  • 🐛 Fix: Fixed a bug where filters data is getting saved in the dashboard json unnecessarily which causes increase in dashboard json size
v3.4.2 - 2022-05-18
  • 🐛 Fix: Fixed a bug where dynatrace queries stopped working with error error loading cache (MetricDefaultAggregation un-marshal error)
v3.4.1 - 2022-03-24
  • New builds with go 1.18 to address CVE-2022-24921
v3.4.0 - 2022-03-21
  • 🚀 Feature: (Config) Allow Skip TLS verify
  • 🚀 Feature: (Config) Allow uploading custom CA certs
  • ⚙️ Chore: Support for enabling the HTTP logger debugging tool
v3.3.4 - 2022-03-14
  • Direct API: Removed limitation of only 5 json fields
  • Direct API: Updated JSON path parser to solve inconsistencies in json path implementations
  • Problems: Variable and tag filtering for problems queries
v3.3.3 - 2022-02-11
  • Metrics: Fixed an issue where filter values are not loaded for some type of entities
  • Metrics: Fixed an issue where dimensions were incorrectly mapped in the metrics alias
  • Metrics: Fixed an issue where the query fails to run when directly into code editor
  • USQL: Fixed an issue where the wild card queries like select * from foo doesn't work in some cases earlier
  • USQL: Query inspector now shows the corresponding API query sent
  • ⚙️ Chore: Fixed an issue in variables editor where the queries doesn't show values for first time
v3.3.2 - 2021-12-06
  • ⚙️ Chore: Enterprise license check update
v3.3.1 - 2021-12-06
  • 🐛 Fix: Management zones are not resolved correctly
  • 📝 Documentation: Updated docs to reflect new query editor options
  • 📝 Documentation: Added more detail around provisioning
  • 📝 Documentation: Added screenshots
v3.3.0 - 2021-11-12
  • 🚀 Feature: Implemented USQL searches
  • 🚀 Feature: Implemented raw api queries
  • 🚀 Feature: Implemented raw metric selector access
  • 🐛 Fix: Fixed a bug where datasource doesn't return data in mixed mode
  • 🚀 Feature: Added annotation support
v3.2.4 - 2021-07-28
  • Fixed transformations. The query editor will migrate queries when first opened. If not opened there is no difference in query behavior. The migration is done so that the :names transformation can be removed, if the merge transformation is required.
v3.2.3 - 2021-07-21
  • 🚀 Feature: You will find entities under a separate heading or "options container" in the filters
  • 🚀 Feature: Configure dynatrace by URL
  • 🐛 Fix: Fixed issue with aggregations, including the percentile aggregation
v3.2.2 - 2021-05-27
  • Updated CHANGELOG
v3.2.1 - 2021-05-27
  • Error with multi tags filters
  • After upgrade, Dynatrace panels throw 400 error "no metrics found using Metric ID"
  • Tags filters not working
  • Dynatrace health check sometimes consuming a LOT of memory
  • Invalid API token returns unhelpful error message
  • Invalid domain returns unhelpful error message
  • Invalid Environment ID returns unhelpful error message
  • Update Dynatrace Documentation
  • Synthetic monitor selection in adhoc template variable results in error
  • enabling Expanded details on problem queries has not effect = no additional details
v3.2.0 - 2021-04-26
  • 🚀 Feature: Only metric names or ad hoc query variables supported for Dynatrace
  • 🐛 Fix: Queries can not be reused between panels
v3.1.4 - 2021-04-12
  • ⚙️ Chore: Update SDK
  • Enabling Expanded details on problem queries has not effect = no additional details
  • Disabling of queries not respected
  • Percentile aggregation error reading
  • Template variables are not supported in problems queries
  • Splitting out problems over multiple dimensions
v3.1.2 - 2021-03-05
  • Series name is using the internal dynatrace ID's in the table view
  • Error code 400 message "unexpected colon expecting key package component or namespace, consider adding a preceding tilde if the token is meant literally"
v3.1.1 - 2021-02-10
  • Empty filter value drop down when selecting new metric from the dashboard variable drop down
  • 🐛 Fix: Fix to filter out dimensions that are not entities
  • Fetching entities should only be done on type = ENTITY
  • 🐛 Fix: Cannot read property 'transformations' of undefined error when closing panel options
v3.1.0 - 2020-11-10
  • 🚀 Feature: Problems API support
  • 🚀 Feature: Support merge transformations
  • 🚀 Feature: Support tag filtering in the v2 metrics API
  • 🐛 Fix: Query with filters stop working when upgrading from 2.1.1 to 3.0.2
  • 🐛 Fix: Can't import the datasource dashboard
  • 🐛 Fix: Images not loading in the plugin readme
v3.0.2 - 2020-09-09
  • 🐛 Fix: Fix for missing filter options (timeseries limit of 1000).
  • Use entities api to get filter key/values instead of metric/query results.
v3.0.1 - 2020-08-03
  • Query Migration updated to handle filter groups and values
  • 🐛 Fix: Fix for missing data
  • 🐛 Fix: Fix filter options
  • 🐛 Fix: Fix single value issue
  • 🐛 Fix: Fix for dimension iteration
  • 🐛 Fix: Fix using name as value for template label
  • 🐛 Fix: Fix for Alias Regex matching
  • Update to backend HealthCheck
v3.0.0 - 2020-07-09
  • Full alerting support
  • Migration to backend plugin
  • Carryover of new features from 2.0.x
  • Ad-hoc filter support
  • More readable filter/dimension names
  • Bug fixes: Aliases are not working & persisted
  • Bug fixes: Host-ID -> how to get a more human readable name from the API
  • Bug fixes: V2 API depreciation messages observed during demo in network inspector
v2.0.0 - 2020-04-10
  • V2 metrics api support
  • Support for synthetic tags
  • Support for monitoring VMware ESXi
  • Performance improvements (subject to delay pending):
  • The amount of data requested
  • The bandwidth/latency of the internet/data connection
  • Support for custom metrics
  • Full templating support for metrics
  • Full templating support for aliases
  • Fully backwards compatible with previous dashboards
  • Requires Grafana 6.5 and up.
v0.9.3 - 2019-09-26
  • Implement alpha metric names api
  • Fixed tag query manager to pull tags based on source type
v0.9.2 - 2019-08-13
  • 🐛 Fix: Tag Query Editor bugs
  • Update packages
v0.9.1 - 2019-08-06
  • Add migration for old tag format to new (fixes breaking change noted in 0.7.0)
  • 🐛 Fix: Fix tag queries for custom/auto and manual tags
  • Update packages
v0.9.0 - 2019-07-15
  • refactor and fix filter editor
  • add migration method for dashboards using old format (0.5.3 and earlier) (Issue #21)
v0.8.0 - 2019-06-07
  • 🐛 Fix: Fix for saving template variables in tags
v0.7.0 - 2019-05-16
  • BREAKING CHANGE: This release includes a breaking change for TAGS. Any queries that leverage tags will need to be updated manually.
  • Bugfixes and Feature additions
  • Updated packages
  • Updated circleci
v0.6.0 - 2019-05-09
  • Template variables support
  • Ad hoc filters support
  • Tags support
  • Able to select metrics by ID or by name
  • Query model was changed, panels may be broken
v0.5.3 - 2019-03-29
  • Use plugin routes for secure authentication
  • Able to configure SaaS or Management environments
  • Cache sources query
  • Metrics without aggregation is not supported
v0.5.2 - 2019-03-23
  • Percentile support
  • Cannot do percentile aggregations
v0.5.0 - 2019-02-19
  • Regex filtering support
  • Bug when no filter specified
  • Use ID instead of Display Name to avoid duplicates
