Plugins 〉DynamoDB
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
DynamoDB
- Overview
- Installation
- Change log
- Related content
- Documentation →
DynamoDB data source for Grafana
The DynamoDB data source allows a direct connection to DynamoDB to query and visualize data in Grafana.
This data source supports PartiQL query syntax and provides an editor to format and color code your PartiQL statements.
See also
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing DynamoDB on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install DynamoDB from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v2.1.6 - 2025-02-12
- ⚙️ Chore: Update dependencies
v2.1.5 - 2025-01-30
- ⚙️ Chore: Add ARN warning
v2.1.4 - 2025-01-20
v2.1.3 - 2025-01-06
- ⚙️ Chore: update backend dependencies
v2.1.2 - 2024-12-13
- ⚙️ Chore: Update backend dependencies
v2.1.1 - 2024-11-22
v2.1.0 - 2024-10-22
- ⚙️ Chore: Update backend and frontend dependencies
- ⚙️ Chore: Minimal supported Grafana version is now
10.4.8
v2.0.1 - 2024-10-15
- ⚙️ Chore: Update settings
v2.0.0 - 2024-10-08
- 🚀 Feature: Update AWS Auth component in config page
- 🚀 Feature: Support session token configuration with AWS credentials file
- BREAKING CHANGE: This release includes a breaking change config page. Should you update the config page, you may lose Access Secret Key. Ensure to have Access Key and Access Secret key to update the config page.
v1.1.3 - 2024-09-29
v1.1.2 - 2024-09-18
v1.1.1 - 2024-09-18
- ⚙️ Chore: add errorsource
v1.1.0 - 2024-09-12
- 📝 Documentation: Update docs
v1.0.5 - 2024-09-10
v1.0.4 - 2024-09-09
v1.0.3 - 2024-08-19
- ⚙️ Chore: update frontend dependencies
v1.0.2 - 2024-07-10
- 📝 Fix: Fix license check
v1.0.1 - 2024-06-21
- 📝 Documentation: Remove BETA from the readme
v1.0.0 - 2024-06-20
- ⚙️ Chore: Stable release
v0.1.1-beta
- Initial beta version
