Plugins 〉Azure DevOps
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Azure DevOps
- Overview
- Installation
- Change log
- Related content
- Documentation →
Azure DevOps data source for Grafana
The Azure DevOps data source plugin allows you to query and visualize Azure DevOps data from within Grafana.
See also
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Azure DevOps on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Azure DevOps from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v0.8.25 - 2025-03-14
- ⚙️ Chore: Add more logging on startup to catch issues
v0.8.24 - 2025-03-13
- 🐛 Fix: Use Raw http on healthcheck if pdc enabled to verify customer issue
v0.8.23 - 2025-03-13
- 🐛 Fix: Add more logging to catch issues in health check
v0.8.22 - 2025-03-12
- ⚙️ Chore: Improve logging
v0.8.21 - 2025-02-24
- ⚙️ Chore: Update logging
v0.8.20 - 2025-02-17
- ⚙️ Chore: Improve error logging
v0.8.19 - 2025-02-11
- ⚙️ Chore: update backend dependencies
v0.8.18 - 2025-02-06
- ⚙️ Chore: update frontend dependencies
v0.8.17 - 2025-02-06
- ⚙️ Chore: Update built-in dashboards
- ⚙️ Chore: Update backend dependencies
v0.8.16 - 2025-01-24
- 📝 Documentation: Fix typos in documentation
v0.8.15 - 2025-01-23
v0.8.14 - 2025-01-20
- ⚙️ Chore: Fix typos in labels and tooltips
v0.8.13 - 2025-01-20
- ⚙️ Chore: Update included dashboards
v0.8.12 - 2025-01-10
v0.8.11 - 2024-12-18
v0.8.10 - 2024-12-16
v0.8.9 - 2024-12-04
- ⚙️ Chore: Fix error source for invalid query type
v0.8.8 - 2024-12-03
- ⚙️ Chore: Fix error source for http downstream errors
v0.8.7 - 2024-11-15
- ⚙️ Chore: Update Component to improve a11y
v0.8.6 - 2024-11-12
- ⚙️ Chore: Updated backend dependencies
v0.8.5 - 2024-10-03
- ⚙️ Chore: Update frontend dependencies
- ⚙️ Chore: Minimal supported Grafana version is now
10.4.8
v0.8.4 - 2024-09-30
- ⚙️ Chore: Improve error source handling
v0.8.3 - 2024-09-24
v0.8.2 - 2024-09-20
v0.8.1 - 2024-08-30
v0.8.0 - 2024-08-01
- 🚀 Feature: Secure socks proxy support added
v0.7.1 - 2024-07-30
- ⚙️ Chore: Improve error source capturing
v0.7.0 - 2024-07-04
- ⚙️ Chore: Updated SDK and Added SLO metrics to the plugin
v0.6.1 - 2024-07-01
v0.6.0 - 2024-06-12
- ⚙️ Chore: Update sdk and use new license checking method
v0.5.2 - 2024-03-13
- ⚙️ Chore: Backend binaries are now compiled with Go version
1.22.1
v0.5.1 - 2024-03-04
- ⚙️ Chore: Update dependencies
v0.5.0 - 2024-02-21
- ⚙️ Chore: Add error source to returned data responses
v0.4.2 - 2024-01-12
v0.4.1 - 2023-11-14
- 🐛 Fix: Fixed bug when "Pipeline runs" query failed if pipeline was running
v0.4.0 - 2023-10-26
- ⚙️ Chore: Update backend and frontend dependencies
9.5.13
v0.3.0 - 2023-08-03
- 🚀 Feature: Added sample dashboards
v0.2.6 - 2023-06-08
- ⚙️ Chore: backend libs updated with golang:1.20.5
v0.2.5 - 2023-05-03
1.20.4
which contains security fixes
v0.2.4 - 2023-04-19
- ⚙️ Chore: Backend dependencies updated
1.20.3
v0.2.3 - 2023-03-15
- 🐛 Fix: Fixed variables selection from repository dropdown in query editor
v0.2.2 - 2023-03-07
- 🐛 Fix: Fixed variables not working in query editor
v0.2.1 - 2023-02-03
- ⚙️ Chore: Fixed an issue where plugin causing crash loop
v0.2.0 - 2023-02-03
- ⚙️ Chore: Internal frontend dependencies updated
- ⚙️ Chore: Minimum required Grafana runtime version is now 8.4.7
v0.1.3 - 2022-12-21
- Backend compiled with the latest go version 1.19.4
- Backend grafana dependencies updated
v0.1.2 - 2022-11-29
- Backend compiled with the latest go version 1.19.3
v0.1.1 - 2022-05-24
- Support for grafana single plugin license
v0.1.0 - 2022-05-16
- Initial release
- List of Projects, Repositories, Builds, Build Definitions, Pipelines, Pipeline Runs, Releases, Release definitions and Release deployments
