Plugins 〉Adobe Analytics
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Adobe Analytics
- Overview
- Installation
- Change log
- Related content
- Documentation →
Grafana Adobe Analytics data source plugin
The Adobe Analytics data source plugin allows you to retrieve reports data from Adobe Analytics.
Project status
NOTE: This plugin is in a public preview. Refer Grafana Labs release life cycle documentation for further details. If you notice any issues or having feature request, create a support ticket with your Grafana Enterprise support channel.
See also
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Adobe Analytics on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Adobe Analytics from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v0.1.12-preview - 2025-03-10
- 🐛 Fix: Increase scopes in authentication request
v0.1.11-preview - 2025-02-10
- 🐛 Fix: upgrade Segment default limit and fix error parsing on reports
v0.1.10-preview - 2025-02-10
- 🐛 Fix: Include all Segment types by default
v0.1.9-preview - 2025-02-10
- ⚙️ Chore: Update backend dependencies
v0.1.8-preview - 2025-02-04
v0.1.7-preview - 2025-02-04
v0.1.6-preview - 2024-12-18
- 🐛 Fix: Bug fix metrics filters segments
v0.1.5-preview - 2024-12-12
- 🚀 Feature: Add support for filtering reports by Segments
v0.1.4-preview - 2024-10-04
- 🐛 Fix: Fix context handling during request
v0.1.3-preview - 2024-09-03
v0.1.2-preview - 2024-07-24
v0.1.1-preview - 2024-07-12
- 🐛 Fix: Fix tooltips in query editor
v0.1.0-preview - 2024-07-12
- 🚀 Feature: Initial release
