Plugins 〉Simple Annotations
Simple Annotations
Grafana Simple Annotations Plugin
Frustrated with using a datasource that doesn't support annotations?
This is a simple annotation plugin for Grafana that works with any Datasource!
It works by using the dashboard.json itself as the store for annotations -- this means that you can easily backup / save / share your annotations.
"annotations": {
"list": [
"datasource": "${DS_SIMPLE_ANNOTATION}",
"enable": true,
"hide": false,
"iconColor": "rgba(255, 96, 96, 1)",
"limit": 100,
"name": "Deployments",
"queries": [
"date": "2017-09-03T19:56:36.000Z",
"text": "First Deployment"
"date": "2017-09-03T20:56:53.000Z",
"text": "Second Deployment"
"date": "2017-09-03T21:56:56.000Z",
"text": "Third Deployment"
"showIn": 0,
"type": "alert"
Development
mkdir grafana
export GOPATH=`pwd`
go get github.com/grafana/grafana
cd $GOPATH/src/github.com/grafana/grafana
go run build.go setup
go run build.go build
npm install
npm install -g grunt-cli
grunt
mkdir -p data/plugins
ln -s ~/Development/simple-annotations data/plugins/simple-annotations
./bin/grafana-server
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Simple Annotations on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Data Source
Use the grafana-cli tool to install Simple Annotations from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
