Plugins 〉SPARQL
Developer
Flanders Make
Data Source
community
SPARQL
  • Overview
  • Installation
  • Change log
  • Related content
Grafana SPARQL Datasource Plugin
Catalog Downloads
This datasource plugin adds support for SPARQL endpoints to Grafana. Under the hood, it uses the Comunica framework.
Screenshots
Configuration
Auto Layout
Specify the url of a SPARQL endpoint and optional credentials for basic HTTP authentication.
Editor
Auto Layout
Collect data via SPARQL queries.
Installing SPARQL on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install SPARQL from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
