Plugins 〉WindRose
WindRose
Windrose Panel for Grafana
Render metrics into a windrose chart.
Screenshots
Environments
For linux ubuntu 16.04, first get nvm installed. some instructions can be found here.
After nvm installation, activate one engine. Here version 8.x is picked for no particular reason.
nvm install v8
nvm use v8
Building
To complie, run:
npm install -g yarn
yarn install --pure-lockfile
grunt
Roadmap
- This plugin is modified from plotly panel for grafana and currently has many inconsistent variable names to be refactored.
Authors and contributors
The Grafana Windrose Plugin was initiated as a part of the joint research project among RCAS, RCEC of Academia Sinica of Taiwan; NCHC, TORI of Natioanl Applied Research Laboratories of Taiwan and Taiwan Generations Corporation. It was developed by Sea Bunny Corporation and released under MIT license.
The contacts of developers are
Chih-Yu Kuo Research Fellow, RCAS, Academia Sinica, Taipei, Taiwan cykuo06@gate.sinica.edu.tw
and
Chun-Yun Wang, Sea Bunny Corporation, Taipei, Taiwan. cloud@seabunny.tech
RCAS: Research Center for Applied Sciences, RCEC: Research Center for Environmental Changes, NCHC: National Center for High-performance Computing, TORI: Taiwan Ocean Research Institute.
The code based is modified from a fork of plotly panel for grafana.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing WindRose on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install WindRose from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
