Plugins 〉Factry Historian Datasource
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
- Overview
- Installation
- Change log
- Related content
Grafana datasource for Factry Historian.
Introduction
Empower anyone to analyze industrial process and event data with Grafana. The Grafana Data Source for Factry Historian makes it easy for users to browse assets, trend time-series and event data such as batches or shifts – with zero technical skills required.
Typical use cases
- Browsing your asset structure (e.g. ISA88/ISA95 equipment model)
- Trending time-series data, while auto-configuring units of measurement
- Overlaying of events (e.g. golden batch analysis)
- Ad-hoc overlaying of time-series data on top of events
Features
- Query historical data using the asset tree defined in Factry Historian
- Query historical data using measurements from Factry Historian
- Autoload Units of Measurement, Y-axis scaling and HI/LO boundaries
- Query Events from Factry Historian (e.g. batches, CIP cycles)
- Annotate trends with Event data from Factry Historian
- Use assets, measurements and events from Factry Historian as variables to build dynamic dashboards
Installation
A full step-by-step guide can be found in the 'Installing Factry Historian Datasource' Tutorial.
Install using the grafana-cli or by cloning the repository directly into the Grafana plugins directory.
grafana-cli plugins install factry-historian-datasource
Configuration
Create a new instance of the data source from the Grafana Data Sources administration page. And configure the necessary settings.
- URL: The URL of the Factry Historian API.
- Token: The API token to authenticate with the Factry Historian API.
- Organization: The UUID of the organization to query data from.
- Default tab: The default tab to show when opening the query editor.
Documentation
Full documentation can be found at the Factry documentation site: https://docs.factry.cloud/docs/grafana-datasource
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Factry Historian Datasource on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Factry Historian Datasource from the commandline:
2. Configure the Data Source
Changelog
v2.2.0
Changes
- Introduced the ability to include parent event information in event queries.
- Implemented support for event property value filters compatible with v7.2.0.
- Added an option to only return changed values in measurement queries.
- Added support for event properties with dimensions in event queries.
- Description of measurements and or asset properties are now available as labels in query results.
Bug Fixes
- Checked the validity of regular expressions before sending them to the historian.
- Fixed issues with custom interval selection in the event query.
- Fixed an issue where modifying a duplicated panel could impact the original panel.
v2.1.0
Bug Fixes
- Resolved issue where only one result was returned when multiple assets were queried in the asset property query.
- Corrected results for asset property queries using a regular expression.
- Ensured re-rendering after mount completion in the query editor.
- Fixed saving of Grafana variables in annotation queries.
- Addressed issue where aggregation reset to 'last' instead of clearing.
Changes
- Enabled aggregation over the entire time period of a dashboard.
- Added variable query for distinct event property values (requires historian > v7.2.0).
- Introduced support for value filters in time series queries (requires historian > v7.1.0).
v2.0.4
Changes
- Fixed logo in the README.
- The datasource now detects the running version of the historian and adapts to the available features.
- Error messages are now more descriptive.
- Enhanced units for event duration.
Bug Fixes
- Resolved styling issue with the dropdown cascader in the asset property query editor.
- Resolved an issue where the repeat by variable feature was malfunctioning.
v2.0.3
Changes
- Fixed filtering of event types in the event query when using a regular expression for the assets
- Fixed event queries when filtering on multiple statuses
v2.0.2
Changes
- Added 'first', 'last' and 'count' as aggregation options for array datatypes
- Fixed event property type selection
- Fixed broken link in the README
- Reworked introduction in the README
v2.0.1
Changes
- Pass datasource request context to the historian client
- Automatic instance management for data source
- Removed pprof code
v2.0.0
Changes
- Enabled annotations for events
- Added dashboard variable query editors for: measurement, databases, assets, asset properties, event types and event type properties
- Improved support for dashboard variables
- Can use everywhere where it makes sense
- Multi-value supported
- Reworked measurement selection, using a regular expression is now a toggle
- Fetch tag keys/values from the historian
- Support periodic values in the event query
- Optionally query asset properties in the event query
- Improved error handling
