Plugins 〉ESNET Matrix Panel
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
ESNET Matrix Panel
- Overview
- Installation
- Change log
- Related content
Matrix Panel Plugin
This plugin creates a 2D matrix showing the relationship between 2 selected fields (source and target). Note: This is NOT inteded to use with time series data or large data sets. It also will not render if there are >200 rows or columns
Options
Display
Source Field: The field you want to use on the vertical axis. Target Field: The field you want to use on the horizontal axis. Value Field: The metric you want to use to color the boxes. Source/Target/Value Text: The text to appear in the tool tip.
Cell Size: The size of each square. This number sets the width of the square in pixels. Cell Padding: The relative padding between each square. Text Length: The max number of characters to include before truncating the label. Using a smaller number here can help prevent Text Size: The size of the text labels
Null Color: The color to use for a square when "null" is returned by the query No Data Color: The color to use for a square when there is no value returned by the query for the specified source and target pair.
Colors
The color of each square will be determined by the selected metric and the color choice in the Standard Options.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing ESNET Matrix Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install ESNET Matrix Panel from the commandline:
grafana-cli plugins install
Changelog
1.0.5
Fixed repo link Fixed bug with null color values
1.0.6
Allow for up to 200 UNIQUE rows and columns Print "No Data" instead of throwing error if dataframe is empty
1.0.9
update grafana tooling to webpack
