Plugins 〉ESnet Chord
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
ESnet Chord
- Overview
- Installation
- Change log
- Related content
Chord Panel Plugin
This is a panel plugin for generating Chord diagrams in Grafana 8.3+. This plugin uses a locally included version of d3.
Data
This plugin uses non time series data and requires each row to have 2 data fields and a metric or value field.
NOTE: If the panel is blank even though your data input is correct, it may be too small. Try resizing the panel until it is large enough to display the chord diagram.
Customizing
Display
Source Field: The query field to use as the source of the chord.
Target Field: The query field to use as the target of the chord.
Value Field: The query field (usually the metric) to be used to determine the thickness of the each chord.
Text Length: The amount of space alloted for labels on the outside of the diagram.
Standard
Units: Set the units for the values in the Standard Options section.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing ESnet Chord on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install ESnet Chord from the commandline:
grafana-cli plugins install
Changelog
1.0.3
First release to Grafana Community plugins
1.0.4
Fix incorrect links
1.0.5
Add option to control outer label font size
