Plugins 〉OData
Developer
d.velop AG
Data Source
community
OData
  • Overview
  • Installation
  • Change log
  • Related content
Grafana OData Data Source
Visualize data from OData data sources with Grafana.
About
This is a Grafana data source for showing data from OData V4 compliant data sources.
It was originally developed for internal purposes and is now made available to the open source community.
Getting started
Open Grafana and go to Configuration / Data Sources. Click Add data source button.
Enter OData into the filter input field and select the OData Data Source.
Add Data Source
Provide the URL of your OData Service Root and click Save & test to test the connection.
The URL space encoding setting can be used to specify the encoding of spaces in URLs. Percent uses %20 (see RFC 3986), while Plus uses + (used in form data). E.g. $filter=value%20EQ%201 vs. $filter=value+EQ+1.
Add other connection settings, such as auth settings, as necessary.
To use the data source, create a new query and select the newly created OData data source.
Choose an entity set, an appropriate time property, and the metric you want to view. Now you should be able to see data for the selected time frame.
Related Links
  • Grafana - the open source analytics & monitoring solution for many data sources
  • Build a Grafana data source plugin - a tutorial that explains how to develop your own data source plugin.
  • OData - the ISO/IEC approved, OASIS standard for building and using data-driven RESTful APIs
Contributing
This project is maintained by d-velop but is looking for contributors. If you consider contributing to this project please read CONTRIBUTING and DEVELOPING for details on how to get started.
License
Please read LICENSE for licensing information.
Installing OData on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install OData from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
[1.1.0] 2024-03-14
Features
  • #2: Made time property optional
  • Updated to go version 1.21
  • Updated to Grafana 10.2
  • Configurable space encoding (%20or +)
[1.0.0] 2023-05-12
Features
  • Initial revision
