Plugins 〉MonetDB
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
MonetDB
- Overview
- Installation
- Change log
- Related content
MonetDB
MonetDB datasource plugin for Grafana
The MonetDB datasource plugin allows you to connect to a MonetDB database instance, to query the data and visualize it in a grafana dashboard.
Adding the datasource
Go to home menu, then select connections. Here you will see the Datasource options. Enter "MonetDB" in the search box and add it. Then enter the connection setting for your database instance.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing MonetDB on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install MonetDB from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
[0.0.1] (Unreleased)
Initial release.
[0.2.0]
Plugin submitted and approved
