Plugins 〉Finnhub
Developer
Alex Khomenko
Data Source
community
Finnhub
  • Overview
  • Installation
  • Change log
  • Related content
Data Source Grafana plugin for Finnhub.
Before starting, it's necessary to get an API token from Finnhub and paste it to the "API Token" field in the plugin settings.
Currently supported queries:
Free API
Premium API
A sample dashboard provisioning file is available at provision/dashboard.json. Read more about dashboards provisioning.
Installing Finnhub on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Finnhub from the commandline:
grafana-cli plugins install
2. Configure the Data Source
0.6.0
  • Add support for $symbol variable
0.5.0
  • Remove @grafana/ui Form usage
  • Update React to v.18
  • Remove unused dependencies
0.4.1
  • Remove grafanaVersion from plugin.json
  • Update grafanaDependency in plugin.json
0.4.0
  • Update the plugin to be compatible with Grafana 10
0.3.2
  • Update dependencies
0.3.1
  • Restore trades endpoint (websocket)
0.3.0
  • Store API token in secure field
  • Temporarily disabled trades websocket endpoint due to proxy auth issue (quote query with dashboard refresh can be used as a workaround).
0.2.1
  • Update the plugin to be compatible with Grafana 8
  • Add social sentiment endpoint support
0.1.1
  • Initial release
