Plugins 〉Materialize
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Materialize
- Overview
- Installation
- Change log
- Related content
Grafana Materialize Data Source
This is a Grafana data source which can connect to the Materialize streaming SQL database. It supports the Grafana Live capabilities for streaming data and hence can be used to visualise data in materialized views 'live'.
Usage
Configuring the datasource
Only three parameters are available for the datasource:
- Host - the hostname of the Materialize database
- Port - the port on which to connect to the Materialize database
- Username - the username as which to connect to the Materialize database
Querying the datasource
When querying the datasource in a new panel you have two options available to you:
- Relation - the query builder will populate a list of available relations in the Materialize database. Select one and the relation will be
TAIL
ed to the panel. - Select statement - input a custom statement into the query field and the output of the statement will be
TAIL
ed to the panel.
Configuring panels
The plugin includes the mz_timestamp
and mz_diff
columns in the streaming output, which may not be what you want to see. The simplest way to solve this is to use the Transformations functionality of the panels. In the panel editor, click the Transform button and add any transformations you like. A good place to start is:
- Organize fields
Use this to hide the
mz_diff
field by clicking the 'eye' symbol next to the field name. - Prepare time series Select Multi-frame time series as the format.
- Rename by regex
Use this to remove any common unwanted prefix from the time series names. E.g. set Match to
avg (.*)
and Replace to$1
to remove the prefixavg
See the 'transforms' screenshot for an example.
Screenshots
https://user-images.githubusercontent.com/5464991/166680691-8df200d7-e354-43bf-a924-8ce9fbc8582a.mov
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Materialize on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Materialize from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
All notable changes to this project will be documented in this file.
The format is based on Keep a Changelog, and this project adheres to Semantic Versioning.
Unreleased
0.1.1 - 2022-08-12
Changed
- Loosened requirements on Grafana to allow the plugin to run on any version greater than 8.4.0.
0.1.0 - 2022-05-04
Initial release.
