Plugins 〉Tokio Console
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Tokio Console
- Overview
- Installation
- Change log
- Related content
Grafana Tokio Console Data Source
This is a streaming Grafana data source which can connect to the Tokio console
subscriber. It provides similar functionality to the console
TUI frontend (albeit more limited at the moment!). It currently supports the 'tasks list' and 'task details' data streams.
Usage
You can create a new Tokio Console data source for each process that you want to connect to. The
Configuring the data source
Only two parameters are available for the data source:
- URL - The address of a console-enabled process to connect to. Equivalent to the
<TARGET_ADDR>
argument of theconsole
TUI. - Retain for - how long to continue displaying completed tasks and dropped resources after they have been closed. Equivalent to the
--retain-for
flag of theconsole
TUI.
Using the data source
The easiest way to use the data source is to import the default dashboards that come with it. To do so, navigate to the data source's settings page and click the 'Dashboards' tab, then click the 'Import' button for all available dashboards.
You can also create arbitrary visualisations of the (streaming) data using Grafana's standard panels + transforms. The recommended path to doing so is to take a look at the panels in the imported dashboards and make incremental changes to a copy of the dashboard.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Tokio Console on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Tokio Console from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
All notable changes to this project will be documented in this file.
The format is based on Keep a Changelog, and this project adheres to Semantic Versioning.
Unreleased
1.0.1
Changed
- Loosened requirements on Grafana to allow the plugin to run on any version greater than 8.4.0.
1.0.0 - 2022-05-06
Initial release.
