Plugins 〉D3 Gauge
Developer
Brian Gann (bkgann@gmail.com)
Panel
community
D3 Gauge
  • Overview
  • Installation
  • Change log
  • Related content
Grafana Gauge Panel
Marketplace Downloads License
Twitter Follow Release Maintainability Test Coverage
All Contributors
This panel plugin provides a D3-based gauge panel for Grafana 8.4.10+/9.x/10.x
Screenshots
Example gauges
Default Gauge
Default Gauge With Threshold
Default Gauge With All Thresholds
Custom Gauge
Custom Gauge With Limits
Configuration Options
The React port has separated the configuration options into multiple searchable sections and added new features.
Standard Options
Standard Options
OptionDescription
StatThe statistic to be displayed on the gauge
UnitA unit for the value displayed. This will be used to abbreviate as needed
DecimalsMaximum number of decimals to display if any are required
Font Settings
Font Settings
OptionDescription
Value FontFont to be used on the value displayed
Value Font SizeFont Size for the value displayed
Tick Label FontFont to be used on the tick labels
Tick Label Font SizeFont size to be used on for the tick labels
Needle Options
Needle Options
OptionDescription
Animate Needle TransitionEnables needle animation between values
Transition Speed (MS)When animation is enabled, set how fast the transition occurs
Allow Crossing LimitsEnable this to allow the needle to go below and above the limit
Needle Cross Limit DegreesWhen crossing limits is enabled, this sets the degrees that can be exceeded
Needle WidthSpecifies the width of the needle
Show End MarkerThis will create a marker at the end of the needle of the specified shape
Show Start MarkerThis will create a marker at the start of the needle of the specified shape
When the options Allow Crossing Limits is enabled, the needle can exceed the maximum or minimum limit by the specified degrees. The example below shows a gauge with a limit of 100, and allows the needle to cross the limit (burying the needle).
Needle Cross Enabled
Limits
Limits
OptionDescription
Minimum ValueMinimum Value allowed on the face
Maximum ValueMaximum Value allowed on the face
Coloring
Coloring
OptionDescription
Outer EdgeColor of the outer edge of the gauge
Inner (Face)Color used on the face of the gauge (background of dial)
PivotColor of the pivot (center)
NeedleColor of the needle
Units LabelColor for label units when displayed
Tick LabelColor of values displayed near the tick major sections
Tick MajorColor of the major ticks (longer lines)
Tick MinorColor of the minitor ticks (shorter lines)
Radial Customization
Note that many of these settings are very sensitive to the visualization since they are percentages of the radius. Adjust in small increments to see how they affect the gauge.
OptionDescription
RadiusSpecifies size of gauge by radius. Value 0 (zero) will auto-scale to fit panel
Tickness Gauge BasisScaling for tick, a lower value will autoscale poorly
Pivot RadiusSize of the center pivot, as a percentage of radius
Value Y-OffsetSets a vertical offset to better place the displayed metric
PaddingAdds space between the ticks and outer edge
Edge WidthThickness of the circle around the edge of the gauge, as a percentage of the gauge radius
Tick Edge GapSpacing between ticks and the outer circle, as a percentage of the gauge radius
Tick Length MajorLength of the major ticks, as a percentage of the gauge radius
Tick Width MajorWidth of the major ticks in pixels
Tick Length MinorLength of the minor ticks, as a percentage of the gauge radius
Tick Width MinorWidth of the minor ticks in pixels
Needle Tick GapSpacing between ticks the needle end, as a percentage of the gauge radius
Needle Length StemLength of the needle section extending beyond the centre of the gauge, as a percentage of the gauge radius
Gauge Degrees
This is the main section that is used to modify the displayed range on the gauge.
Gauge Degrees
OptionDescription
Zero Tick AngleAngle where the tick value (0) starts (default 60)
Max Tick AngleAngle where the tick value ends (default 300)
Zero Needle AngleAngle where needle is at minimum value (default 40)
Max Needle AngleAngle where needle is at maximum value (default 320)
Gauge Readings
Gauge Readings
OptionDescription
Tick Spacing MajorThe numeric spacing of the minor increment ticks
Tick Spacing MinorThe numeric spacing of the major increment ticks
Tick Maps
Tick Maps
Use the Add Tick Map button to create a tick map.
A tick map allows you to substitute text for a given value. Using this option a compass style gauge can be constructed.
OptionDescription
LabelSets the name of the Tick Map
ValueTick value where the text will be placed
TextText to be displayed
Thresholds
Thresholds operate in the same manner as other Grafana plugins.
There are additional display options detailed below.
Thresholds
OptionDescription
Show Threshold Band On GaugeThresholds are displayed as a band on face of gauge along the needle arc
Show Lower RangeLower threshold is displayed on band
Show Middle RangeMiddle thresholds are displayed on band
Show Upper RangeUpper threshold is displayed on band
Show Threshold State on BackgroundGauge face color changes to state of threshold
Show Threshold State on ValueDisplayed value color changes to state of threshold
When the middle and upper threshold option are selected, the gauge will look similar to this:
Thresholds Middle Upper
The state of the threshold can be displayed as the background color of the gauge.
Threshold on Face
The state of the threshold can be displayed on the value of the gauge.
Threshold on Value
Value Mappings
Value Mappings works the same as other Grafana plugins. This allows displaying alternative text instead of the value based on ranges or regular expressions.
Primarily this is used for N/A for null data, but can be used to indicate a state.
Ex: For a temperature gauge, a value below 0 could be harmful, or a value above 100 could be harmful to a device. A value mapping could be used to display this as an urgent message, or simply indicate a "nominal" reading.
Value Mappings
Features
  • Data operator same as SingleStat panel (avg, sum, current, etc)
  • Unit formats same as SingleStat
  • Customizable Font size and type for value displayed and ticks
  • Animated needle transition (elastic or quadin)
  • Adjustable Limits
  • All possible color options for gauge components
  • Customizable gauge component sizes (needle length, width, tick length, etc)
  • Threshold colors displayed on gauge
  • Threshold can modify displayed value and background
  • Needle animation speed is configurable
  • Arbitrary degree gauges now supported (default is from 60 to 320)
  • Value text on gauge can now be moved up/down as needed
Contributing
All contributions are welcome! See the CONTRIBUTING.md doc for more information.
Acknowledgements
This panel is based on the "SingleStat" panel by Grafana, along with large portions of these excellent D3 examples:
Contributors
Installing D3 Gauge on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install D3 Gauge from the commandline:
grafana-cli plugins install
Change Log
All changes noted here.
v2.0.1 - 2023-11-13
  • Fix font sizing during migrations
  • Autoscales font according to gauge size
v2.0.0 - 2023-10-20
  • Rewritten from Angular to React
  • NEW: Needle Width can now be specified
  • NEW: Thresholds now use the standard Grafana threshold mechanics
  • NEW: Needle can optionally exceed the tick mark (min and max) to show values that are outside of limits
  • NEW: Needle Center can use all marker types, with arrow-inverse added to options
  • Switched to pnpm
v0.0.9 - 2021-04-21
  • Add option to display needle arrow
  • Update packages
v0.0.8 - 2020-10-26
  • Signed Plugin!
  • Updated build process
v0.0.7 - 2020-04-18
  • Fixes
    • Update to typescript and using standardized build process.
    • Simplified value display
v0.0.1
  • Initial commit
