Plugins 〉Archilogic Floor Panel plugin
This document provides an overview of the Archilogic plugin for Grafana, including installation and configuration instructions, and an explanation of how to use the plugin in order to better visualize your data.
Introduction
The Archilogic plugin for Grafana gives users the ability to load floor plans stored in Archilogic within Grafana dashboards, map information from data sources to elements in space, and visualize information on floor plans.
The plugin provides a range of features including the ability to customize visualization styles, interact with the model using touch or mouse controls, and use entities in the floor plan to filter information in other Grafana components. The plugin uses Archilogic’s Floor Plan Engine SDK, which you can find more details about below.
Requirements
Grafana 8.2.0+
Installation
Use the grafana-cli tool to install from the command line:
grafana-cli plugins install archilogic-floor-panel
Navigate to Grafana in your browser and log in. Go to the plugin list, search for Archilogic Floor Panel, and enable the plugin.
Provide floor plan ID and publishable token, or use the default ones for demo:
- Floor plan ID
edd55163-b23b-48f3-a602-ea5a0e65809 - Publishable token
d5b83363-ddf0-4775-b6a3-0843dcd756ed
Configure a datasource
To connect the datasource to the plugin, please ensure you have a compatible datasource set up in Grafana that provides the required data format. The data format should consist of a series of node IDs and corresponding values ranging from 0 to 10. Node IDs must belong to the defined floor plan ID from the Floor Panel plugin.
Documentation
You can find more information about the Archilogic Floor Plan SDK, including documentation and examples, in the following places:
Development
If you are interested in developing and contributing to this project, check out the git repository here.
License
Apache License Version 2.0, see LICENSE.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Archilogic Floor Panel plugin on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Archilogic Floor Panel plugin from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.0.0 (Unreleased)
Initial release.
