Plugins 〉MUX-Datasource
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
MUX-Datasource
- Overview
- Installation
- Change log
- Related content
MUX datasource
Visualize data from MUX.
About MUX: https://www.mux.com/
Feature
- Query timeseries metrics with Filters
- API Access Token Setting with secure json
- Suggest filters from breakdown result
MUX API Access Token
You can get the api access token as follows.
https://docs.mux.com/core/stream-video-files#1-get-an-api-access-token
Configure the datasource in Grafana
Required fields
- Access Token ID
- Access Token Secret
Configure the data source via provisioning
You can configure this data source with Grafana provisioning system.
For mode infomation, see Provisioning Grafana.
apiVersion: 1
datasources:
- name: MUX Data
type: arabian9ts-mux-datasource
access: proxy
orgId: 1
version: 1
editable: false
secureJsonData:
accessTokenId: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
accessTokenSecret: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing MUX-Datasource on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install MUX-Datasource from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
