Plugins 〉Track Map
The Track Map plugin has been deprecated and is no longer maintained.
Track Map
Trackmap Panel for Grafana
Map plugin to visualize timeseries data from geo:json or NGSIv2 sources as either a Ant-path, Hexbin, or Heatmap.
Usage
Queries
It's important for the plugin to work, that the
Format asis set toTable.
To use the plugin the data needs to be formatted as a table which either contains simple lat and lon, or as location in NGSIv2 format. Here is a example of how the data from the query should look like using location:
"columns": [
"text": "location"
"rows": [
"type": "geo:json",
"value": {
"type": "Point",
"coordinates": [56.171884, 10.189101]
"type": "geo:json",
"value": {
"type": "Point",
"coordinates": [56.18803, 10.16773]
"type": "table"
A example of a query for location against a CrateDB/PostgreSQL:
SELECT time_index, location
FROM table_name
WHERE $__timeFilter(time_index)
ORDER BY time_index
And a example query for lat and lon against a CrateDB/PostgreSQL:
SELECT time_index, latitude as lat, longitude as lon
FROM table_name
ORDER BY time_index
To only get specific entities from the database a query could look like this:
SELECT location, time_index
FROM table_name
AND (entity_id = 'vehicle:WasteManagement:id1' OR entity_id = 'vehicle:WasteManagement:id2')
ORDER BY time_index
Settings
You can change the starting zoom and center of the map, as well as the maximum zoom under the map options:
There is a options to enable the use of the maps min and max coordinates.
This adds $maxLat, $minLat, $maxLon and $minLon as variables in the dashboard, with the maps bounding box.
Which can then be used in the query, as an example for CrateDB/PostgreSQL:
FROM table_name
AND latitude >= $minLat
AND latitude <= $maxLat
AND longitude >= $minLon
AND longitude <= $maxLon
ORDER BY time_index
To use this with NGSIv2 data, is a bit more complex, an example for CrateDB/PostgreSQL:
SELECT coordinates[1] as lat, coordinates[2] as lon, time_index
FROM (
SELECT location['value']['coordinates'] as coordinates, time_index
FROM table_name
) AS alias
WHERE coordinates[1] >= $minLat
AND coordinates[1] <= $maxLat
AND coordinates[2] >= $minLon
AND coordinates[2] <= $maxLon
ORDER BY 3
An option for the map to update the data after moving/zooming, is available when using the maps min and max coordinates. Do note that enabling this might make it spam your database, and can queue op request to it.
There are three visualization options to choose from, Hexbin, Heatmap and Antpath.
Hexbin
The hexbin have 2 options.
Color rangewhich lets you set the colors of the hexbin based on there value (number of datapoints with the hexbin), with the left color being the lowest count, and the right color being the highest count.- And
Radius rangewith the first field being the initial size of the hexbin changing to the size of the second field.
Heatmap
There are no settings available for Heatmap
Antpath
The antpath have the following options available:
Delay: The delay of the animation fluxDash array: The size of the animated dashesWeight: The weight of the pathColor: The color of the pathPulse color: Adds a color to the dashed fluxPaused: Toggle stop/start of the animationReverse: Reverses the animation flow
Build
To build the plugin, you need either yarn or npm.
First you need to install the dependencies by running:
npm install
After the dependencies are installed, you can build the plugin by running the following command:
npm run build
You can also run the code in development with the following command:
npm run dev
Install
If you are running grafana locally, you can clone or download the repository directly into the plugin directory of grafana, and then reset the grafana-server, and the plugin should be automatically detected.
Or if you are using docker, a guide can be found here.
There are more ways to install plugins for grafana, which can be found on their website.
Contributing
A guide on how to contribute can be found here
Acknowledgements
This plugin was developed as part of the the SynchroniCity Project by The Alexandra Institute. The SynchroniCity project has received funding from the European Union’s Horizon 2020 research and innovation programme under grant agreement No 732240
License
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Track Map on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
Marketplace plugins
This is a paid plugin developed by a marketplace partner. To purchase an entitlement, sign in first, then fill out the contact form.
Get this plugin
This is a paid for plugin developed by a marketplace partner. To purchase entitlement please fill out the contact us form.
What to expect:
- Grafana Labs will reach out to discuss your needs
- Payment will be taken by Grafana Labs
- Once purchased the plugin will be available for you to install (cloud) or a signed version will be provided (on-premise)
Thank you! We will be in touch.
1. Install the Panel
Use the grafana-cli tool to install Track Map from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
