Plugins 〉Vega
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Vega
- Overview
- Installation
- Change log
- Related content
Grafana-Vega
This is a panel plugin for Grafana that allows you to configure Vega or Vega-Lite specs.
Features
The ability to write Vega/Vega Lite specs, which are much more powerful than the inbuilt Grafana vizes. (Gallery). <3 Vega.
A JSON editor with the Vega specs hooked up to it for autocomplete
Field names and Datasource names also hooked up to autocomplete
Automatic light/dark mode as per your Grafana theme
An obsessive amount of mucking about with React to stop your spec being reparsed all the time
{"width": "container"}
hooked up to work like you want
Todo
Rig up Edit in Vega Editor and the other things you expect from Vega Embed
Dig into if it's possible to cope when Grafana sends us multiple dataframes with the same name/refId
Get it signed
Acknowledgements
The Vega project, you guys rock.
Sam Schick's prior art doing the same thing, https://github.com/schicks/vega-grafana
Gapit's generic HTML plugin, https://grafana.com/grafana/plugins/gapit-htmlgraphics-panel/ , which I used as a reference to get the nice editor working, and additionally for letting Vega panels be used in a pinch before I wrote this!
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Vega on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Vega from the commandline:
grafana-cli plugins install
Changelog
1.0.11
- Switch bundler to Vite for AMD support
1.0.10
- Fix rich text in schema autocomplete
1.0.9
- Fix endless rerender loop when editing
1.0.8
- Ensure provisioning works
1.0.7
- Make dark theme better
1.0.6
- Wire up Vega support (previously just Vega-Lite worked)
1.0.4
- Initial release.
