This is documentation for the next version of Grafana k6 documentation. For the latest stable release, go to the latest version.
Secret source
Secret sources provide a secure way for k6 to retrieve and use secrets. Unlike values from environment variables or files, values from secret sources are automatically redacted from k6 logs before propagation through the system.
Access secrets through the
k6/secrets JavaScript API. All secrets are redacted from logs.
Configure secret sources
Configure secret sources using the --secret-source CLI flag. You can configure multiple secret sources simultaneously.
Built-in secret sources
The following built-in secret sources are available for local testing:
file: Reads secrets from akey=valuefile.mock: Reads secrets from CLI arguments.url: Fetches secrets from HTTP endpoints.
Secret source extensions
You can implement a secret source as an extension for k6.
Example script
import http from 'k6/http';
import secrets from 'k6/secrets';
export default async () => {
const my_secret = await secrets.get('cool'); // Retrieves secret by identifier
console.log(my_secret);
const response = await http.asyncRequest('GET', 'https://httpbin.org/get', null, {
headers: {
'Custom-Authentication': `Bearer ${await secrets.get('else')}`,
console.log(response.body);
};Run the script with the following secrets file:
cool=some
else=sourceThe following output shows how secrets are redacted in logs, shown as ***SECRET_REDACTED***, while remaining accessible to the script.
$ k6 run --secret-source=file=file.secret secrets.test.js
INFO[0000] ***SECRET_REDACTED*** source=console
INFO[0001] {
"args": {},
"headers": {
"Custom-Authentication": "Bearer ***SECRET_REDACTED***",
"Host": "httpbin.org",
"User-Agent": "k6/0.57.0 (https://k6.io/)",
"X-Amzn-Trace-Id": "Root=1-67dd638b-4243896a2fa1b1b45bc63eaa"
"origin": "<my actual IP>",
"url": "https://httpbin.org/get"
} ***SECRET_REDACTED***=console
