This is documentation for the next version of Grafana k6 documentation. For the latest stable release, go to the latest version.
Simulate user input delay
On this page, you’ll learn how to best work with sleep in k6 and the various wait* prepended methods available in k6/browser to simulate user input delay, wait for navigations, and wait for element state changes. By the end of this page, you should be able to successfully use the correct API where necessary.
Note
While using the
sleeporpage.waitForTimeoutfunctions to wait for element state changes may seem helpful, it’s best to avoid them to prevent flakey tests. Instead, it’s better to use the otherwait*prepended methods listed on this page.
What is sleep?
sleep is a first class function built into k6. It’s main use is to “suspend VU execution for the specified duration” which is most useful when you want to simulate user input delay, such as:
- Navigating to a page.
- Sleeping for one second to simulate a user looking for a specific element on the page.
- Clicking on the element.
Warning
sleepis a synchronous function that blocks the JavaScript event loop, which means that all asynchronous work will also be suspended untilsleepcompletes.The browser module predominantly provides asynchronous APIs, so it’s best to avoid working with
sleep. Instead, use the page.waitForTimeout function. Refer to When to use sleep() and page.waitForTimeout() for more details.
What is wait*?
In the browser modules there are various asynchronous APIs that can be used to wait for certain states:
browserContext.waitForEvent
browserContext.waitForEvent is used when waiting for specific events to fire, which then returns the element associated to that event. At the moment the only event that is available to use is page. It can be useful when you want to track and retrieve a new tab opening. When working with a predicate function, it can be used to wait for a specific page to open before returning true.
import { browser } from 'k6/browser';
export const options = {
scenarios: {
ui: {
executor: 'shared-iterations',
options: {
browser: {
type: 'chromium',
export default async function () {
const page = await browser.newPage();
await page.goto('https://test.k6.io/');
await page.keyboard.down('ControlOrMeta');
// Open the link in a new tab with the help of the meta key.
// Wait for the new page to be created.
const browserContext = browser.context();
const [newTab] = await Promise.all([
browserContext.waitForEvent('page'),
page.locator('a[href="/my_messages.php"]').click(),
await page.keyboard.up('ControlOrMeta');
// Wait for the new page (tab) to load.
await newTab.waitForLoadState('load');
// Take screenshots of each page.
await page.screenshot({ path: `screenshot-page.png` });
await newTab.screenshot({ path: `screenshot-newTab.png` });
await newTab.close();
await page.close();
}page.waitForFunction
page.waitForFunction is useful when you want more control over when a test progresses with a javascript function that returns true when a condition (or many conditions) is met. It can be used to poll for changes in the DOM or non-DOM elements and variables.
import { check } from 'https://jslib.k6.io/k6-utils/1.5.0/index.js';
scenarios: {
browser: {
options: {
browser: {
type: 'chromium',
try {
// Setting up the example that will mutate the h1 element by setting the
// h1 elements text value to "Hello".
await page.evaluate(() => {
setTimeout(() => {
const el = document.createElement('h1');
el.innerHTML = 'Hello';
document.body.appendChild(el);
}, 1000);
// Waiting until the h1 element has mutated.
const ok = await page.waitForFunction("document.querySelector('h1')", {
polling: 'mutation',
timeout: 2000,
await check(ok, {
'waitForFunction successfully resolved': async (ok) => (await ok.innerHTML()) == 'Hello',
} finally {
await page.close();
}page.waitForLoadState
page.waitForLoadState is useful when there’s no explicit navigation, but you need to wait for the page or network to settle. This is mainly used when working with single-page applications or when no full page reloads happen.
scenarios: {
browser: {
options: {
browser: {
type: 'chromium',
try {
// Goto a SPA
await page.goto('<url>');
// ... perform some actions that reload part of the page.
// waits for the default `load` event.
await page.waitForLoadState();
} finally {
await page.close();
}page.waitForNavigation
page.waitForNavigation is a very useful API when performing other actions that could start a page navigation, and they don’t automatically wait for the navigation to end. Usually, you’ll find it in our examples with a click API call. Note that
goto is an example of an API that doesn’t require waitForNavigation since it will automatically wait for the navigation to complete before returning.
It’s important to call this in a Promise.all along with the API that will cause the navigation to start.
scenarios: {
browser: {
options: {
browser: {
type: 'chromium',
try {
await page.goto('https://test.k6.io/my_messages.php');
await page.locator('input[name="login"]').type('admin');
await page.locator('input[name="password"]').type('123');
const submitButton = page.locator('input[type="submit"]');
// The click action will start a navigation, and the waitForNavigation
// will help the test wait until the navigation completes.
await Promise.all([page.waitForNavigation(), submitButton.click()]);
} finally {
await page.close();
}page.waitForResponse
page.waitForResponse waits for an HTTP response that matches the specified URL pattern. This method is particularly useful for waiting for responses from AJAX/fetch requests, API calls, or specific resources to be loaded before proceeding with the test.
import { check } from 'k6';
scenarios: {
ui: {
options: {
browser: {
type: 'chromium',
try {
await page.goto('https://quickpizza.grafana.com/');
// Test waitForResponse with user interaction
const pizzaResponsePromise = page.waitForResponse('https://quickpizza.grafana.com/api/pizza');
await page.getByRole('button', { name: /pizza/i }).click();
const pizzaResponse = await pizzaResponsePromise;
// Check that the pizza API call was successful
check(pizzaResponse, {
'pizza API status is 200': (r) => r.status() === 200,
'pizza API URL is correct': (r) => r.url() === 'https://quickpizza.grafana.com/api/pizza',
} finally {
await page.close();
}page.waitForRequest
page.waitForRequest waits for an HTTP request that matches the specified URL pattern. This method is particularly useful for waiting for requests to be initiated before proceeding with the test, such as verifying that form submissions or API calls are triggered.
scenarios: {
ui: {
options: {
browser: {
type: 'chromium',
try {
// Test waitForRequest with user interaction
const pizzaRequestPromise = page.waitForRequest('https://quickpizza.grafana.com/api/pizza');
const pizzaRequest = await pizzaRequestPromise;
// Check that the pizza API request was initiated
check(pizzaRequest, {
'pizza API method is POST': (r) => r.method() === 'POST',
} finally {
await page.close();
}page.waitForTimeout
page.waitForTimeout will wait the given amount of time. It’s functionally the same as k6’s sleep, but it’s asynchronous, which means it will not block the event loop and allows the background tasks to continue to be worked on.
scenarios: {
browser: {
options: {
browser: {
type: 'chromium',
try {
// Slow the test down to mimic a user looking for the element on the page.
await page.waitForTimeout(1000);
// ... perform the next action
} finally {
await page.close();
}page.waitForURL
page.waitForURL waits for the page to navigate to the specified URL. This method is useful for ensuring that navigation to a particular URL has completed before proceeding with the test. This is especially useful if there are multiple redirects before hitting the end destination.
scenarios: {
browser: {
options: {
browser: {
type: 'chromium',
try {
await page.goto('https://quickpizza.grafana.com/test.k6.io/');
// Wait for navigation to a specific URL
await Promise.all([
page.click('a[href="/my_messages.php"]'),
page.waitForURL('https://quickpizza.grafana.com/my_messages.php'),
// Wait for navigation using URL pattern with RegExp
await Promise.all([page.click('a[href="/browser.php"]'), page.waitForURL(/\/browser\.php$/)]);
} finally {
await page.close();
}locator.waitFor
locator.waitFor will wait until the element meets the waiting criteria. It’s useful when dealing with dynamic websites where elements may take time to appear or change state. For example, if elements load after some delay due to async calls, or because of slow JavaScript execution.
scenarios: {
browser: {
options: {
browser: {
type: 'chromium',
await page.goto('https://test.k6.io/browser.php');
const text = page.locator('#input-text-hidden');
await text.waitFor({
state: 'hidden',
