Plugins ใ€‰Snowflake
Developer
Grafana Labs
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
grafana
Enterprise
Snowflake
Documentation โ†’
Instantly visualize Snowflake data in Grafana
The Snowflake data source plugin is the easiest way to pull Snowflake data directly into Grafana dashboards.
  • Visualize it either in isolation (one database) or blend it with other data sources.
  • Discover correlations and covariances across all your data in minutes.
Installing Snowflake on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Snowflake from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
v1.14.0 - 2025-04-16
  • ๐Ÿš€ Feature: Add Support for Row Limits in Response
v1.13.1 - 2025-03-27
  • โš™๏ธ Chore: Update backend dependencies
v1.13.0 - 2025-03-12
  • ๐Ÿ› Fix: Fix PDC not working with keypair
v1.12.7 - 2025-02-17
  • โš™๏ธ Chore: Improve error logging
v1.12.6 - 2025-02-11
v1.12.5 - 2025-02-04
  • โš™๏ธ Chore: Update frontend dependencies
v1.12.4 - 2025-01-10
v1.12.3 - 2025-01-06
  • โš™๏ธ Chore: update backend dependencies
v1.12.2 - 2024-12-18
v1.12.1 - 2024-12-16
v1.12.0 - 2024-11-28
  • โš™๏ธ Chore: Bump backend dependencies
v1.11.1 - 2024-11-12
  • โš™๏ธ Chore: Updated backend dependencies
v1.11.0 - 2024-11-11
v1.10.7 - 2024-10-21
  • โš™๏ธ Chore: updating e2e test selectors
v1.10.6 - 2024-10-03
  • โš™๏ธ Chore: Minimal supported Grafana version is now 10.4.8
v1.10.5 - 2024-09-23
v1.10.4 - 2024-08-30
v1.10.3 - 2024-08-13
v1.10.2 - 2024-07-09
  • ๐Ÿ› Fix: Fix license check
v1.10.1 - 2024-06-05
  • โš™๏ธ Chore: updating code dependencies
v1.10.0 - 2024-05-29
  • ๐Ÿš€ Feature: adds official example logs dashboard from snowflake
v1.9.0 - 2024-05-20
  • ๐Ÿš€ Feature: adding traces support for queries learn more
  • ๐Ÿš€ Feature: adding official Snowpark metrics example dashboard from Snowflake
  • โš™๏ธ Chore: updating dependencies to latest versions
v1.8.5 - 2024-04-12
  • โš™๏ธ Chore: updating snowflake go-driver for bug fixes regarding zombie DBus processes
v1.8.4 - 2024-03-13
  • โš™๏ธ Chore: Backend binaries are now compiled with Go version 1.22.1
v1.8.3 - 2024-03-11
  • โš™๏ธ Chore: updating backend dependencies
v1.8.2 - 2024-03-05
  • โš™๏ธ Chore: Update dependencies
v1.8.1 - 2024-02-07
  • ๐Ÿ› Fix: adds onBlur event handler on the VariableQueryEditor
v1.8.0 - 2023-11-24
  • โš™๏ธ Chore: Minimal supported Grafana version is now 9.5.13
  • โš™๏ธ Chore: Backend dependencies updated
  • โš™๏ธ Chore: Frontend dependencies updated
v1.7.1 - 2023-11-01
  • โš™๏ธ Chore: update snowflake go driver to latest version 1.6.25
v1.7.0 - 2023-10-05
  • โš™๏ธ Chore: allow secure session settings and update snowflake drivers to latest version
v1.6.4 - 2023-08-24
  • ๐Ÿ“ Documentation: update customer requirement copy
  • โš™๏ธ Chore: grafana backend plugin sdk updated to v0.171.0
v1.6.3 - 2023-07-18
  • ๐Ÿ› Fix: better handling of session timeouts
v1.6.2 - 2023-06-28
  • โš™๏ธ Chore: Upgrade to version snowflakedb/gosnowflake - v1.6.19
v1.6.1 - 2023-06-08
  • โš™๏ธ Chore: backend libs updated with golang:1.20.5
v1.6.0 - 2023-05-30
  • ๐Ÿš€ Feature: Secure Socks Proxy support added
  • ๐Ÿ“ Documentation: Update docs with OAuth instructions
v1.5.2 - 2023-05-11
  • ๐Ÿ› Fix: variable query editor - don't run query on every keystroke
v1.5.1 - 2020-05-08
  • โš™๏ธ Chore: remove deprecated plugin/toolkit
v1.5.0 - 2023-04-26
  • ๐Ÿš€ Feature: OAuth passthrough
v1.4.3 - 2023-05-04
  • โš™๏ธ Chore: Backend binaries are now compiled with golang 1.20.4
v1.4.2 - 2023-04-19
  • โš™๏ธ Chore: Backend binaries are now compiled with golang 1.20.3
v1.4.1 - 2022-12-13
  • โš™๏ธ Chore: Backend binaries compiled with latest go version 1.19.4
  • ๐Ÿ“ Documentation: Fixed typos and added spellcheck
v1.4.0 - 2022-11-03
  • ๐Ÿš€ Feature: Added support for session parameters in the data source config
  • โš™๏ธ Chore: Backend binaries compiled with latest go version 1.19.3
  • โš™๏ธ Chore: Backend grafana plugin SDK updated to latest
  • โš™๏ธ Chore: Backend snowflake sdk updated to latest
  • โš™๏ธ Chore: Minimum required grafana runtime updated to 8.4.7
v1.3.0 - 2022-09-27
  • Added $__timeTzFilter macro. It functions the same as $__timeFilter for time fields that have a timezone.
v1.2.4 - 2022-08-09
  • ๐Ÿ› Fix: Fixed $__timeFilter to correctly convert from UTC to other timezones
v1.2.3 - 2022-01-10
  • โš™๏ธ Chore: update driver to latest version
v1.2.2 - 2022-01-10
  • โš™๏ธ Chore: update licensing
v1.2.1 - 2021-10-21
  • ๐Ÿ› Fix: Fixes connection issue when multiple instances of the data source are configured.
v1.2.0 - 2021-10-06
  • ๐Ÿš€ Feature: Support for Key Pair Authentication
  • ๐Ÿš€ Feature: Ability to configure the default query, default variable query
  • ๐Ÿš€ Feature: Ability to set the minimum interval
  • ๐Ÿš€ Feature: Now variable queries always queried as Table format
  • ๐Ÿš€ Feature: Ability to set variable list display values
  • ๐Ÿš€ Feature: Ability to configure timeout duration for queries
  • ๐Ÿš€ Feature: $__timeFilter() macro now accepts optional second parameter to specify timezone
  • ๐Ÿš€ Feature: $__timeGroup() macro now accepts optional third parameter to specify timezone
  • ๐Ÿš€ Feature: Ability to set the default variable interpolation format. By default, It uses none formatting for now. In the future versions, this option will be removed and set to sqlstring by default. If you are creating new datasources, use sqlstring as the default. We also recommend to migrate existing queries to use sqlstring to avoid migration issues in future.
  • BREAKING: Now, Automatically we set the minimum interval to 10s if not configured. So any timeseries queries that span across smaller duration and use $__interval or $__interval_ms macros now use 10s as minimum interval by default. You can override the minimum interval in the config.
  • BREAKING: Now variable queries are queried using Table format. In rare cases, If the existing variable query was designed to only work with timeseries format, you may need to rewrite the variable query
  • BREAKING: If the snowflake variable query return two columns, the second column will be now treated as display value. Previously the values from the second column were ignored.
v1.1.1 - 2021-06-21
  • Docs update
  • Save the query on type
v1.1.0 - 2021-06-15
  • BREAKING: Multiple queries in same panel now run in parallel
  • โš™๏ธ Chore: Updated the backend SDK to support automatic instance management
  • ๐Ÿ› Fix: Fixed a bug where hiding/disabling queries are not respected
  • ๐Ÿ› Fix: Fixed a bug where all the data-frame name referred as results instead refID
v1.0.9 - 2021-05-12
  • Updated the backend SDK to support SQL convertors
  • Improved healthcheck errors
v1.0.8 - 2021-04-12
  • โš™๏ธ Chore: Update SDK
v1.0.7 - 2021-02-01
  • Updated screenshot URLs in the readme file
v1.0.6 - 2020-12-16
  • Added scoped variables and allowed the timeGroup macro to work with $__interval_ms
v1.0.5 - 2020-12-09
  • Fixed regression where the timeGroup macro did not understand $__interval or $__interval_ms
v1.0.4 - 2020-12-08
  • Fixed issue where the timeGroup macro was not rendering the correct value in its rendered TIME_SLICE function
v1.0.3 - 2020-11-19
  • Package Updates (sqlds)
  • Default Query is now more useful
v1.0.2 - 2020-10-26
  • Documentation updates
v1.0.1 - 2020-10-26
Update readme with images, a plugin description and a Getting Started guide
v1.0.0 - 2020-09-25
Initial release
