Plugins 〉Business Links
Dependencies
Grafana
Developer
Last updated
Learn how to leverage new AI features and observability tools, attend technical deep dives, & leave with tips for growing your observability strategy.
Sign up to save the date
Bring your crew,
save up to 20%
Don't miss out—Be the first to dive into Grafana 12, Prometheus 3.0, and our nearly sold-out hands-on labs on Grafana as Code, OpenTelemetry, and more.
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Business Links
- Overview
- Installation
- Change log
- Related content
Business Links Panel for Grafana
Introduction
The Business Links panel for Grafana provides a streamlined interface to navigate effortlessly using external links, internal dashboards, time pickers, and dynamic dropdown menus.
Designed for seamless integration, it enables users to access critical resources, switch between dashboards, or interact with custom workflows efficiently, all within a single, intuitive panel.
Requirements
- Business Links Panel 2.x requires Grafana 11.5 or 12.
- Business Links Panel 1.x requires Grafana 11 or 12.
Installation
Install the plugin using one of these methods:
Grafana Plugins Catalog
Visit grafana.com/plugins/volkovlabs-links-panel and follow the instructions.
Grafana CLI
grafana cli plugins install volkovlabs-links-panel
Getting Started
Check out our installation guide:
Features
- External Links: Connect to external tools, documentation, or websites directly from the panel.
- Dashboard Navigation: Quickly jump to other Grafana dashboards for a cohesive monitoring experience.
- Dynamic Dropdowns: Utilize interactive dropdown menus to filter data or trigger actions, enhancing user control and flexibility.
- Business AI: Leverage artificial intelligence to analyze business data, uncover trends, predict outcomes, and provide actionable insights for informed decision-making.
Ideal for teams needing centralized access to diverse resources, the Business Links panel boosts productivity and simplifies navigation in Grafana environments.
Business Suite for Grafana
The Business Links Panel is part of the Business Suite, a collection of open-source plugins by Volkov Labs. These plugins solve common business needs with intuitive interfaces, detailed documentation, and video tutorials.
License
Licensed under the Apache License 2.0.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Business Links on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Business Links from the commandline:
grafana-cli plugins install
Changelog
All notable changes to the Business Links panel are documented in this file. This changelog follows the Keep a Changelog format and adheres to Semantic Versioning.
[2.2.0] - 2025-08-18
Added
- Grid Options: Added support for customizable row height and width. (#63)
- MCP Servers: Introduced new functionality for MCP Servers. (#56)
- Timepicker Highlight: Added option to highlight time differences in the timepicker. (#66, #67)
Changed
- Time Range in URL: Now using raw values for time range in URLs. (#59)
- ESLint Configuration: Updated ESLint settings for better code quality. (#60)
- Sticky Positioning: Improved sticky positioning for dynamic layouts. (#62)
- Time Picker: Enhanced manual and relative time picker to support additional time ranges. (#64)
- Link URL Handling: Updated to allow duplicate
characters in link URLs. (#65)
[2.1.0] - 2025-07-06
Added
- Custom AI Assistant Name: Users can now personalize the name of their AI assistant. (Issue #50)
- Temperature Option for LLM Models: Introduced a new setting to adjust the temperature of language models for more tailored responses. (Issue #51)
Changed
- File Upload Feature: Enhanced the file upload functionality in Business AI for a smoother user experience. (Issue #51)
- Error Messaging: Improved error messages in Business AI to provide clearer feedback. (Issue #51)
[2.0.0] - 2025-06-27
We're excited to announce the release of version 2.0.0 of the Business Links plugin for Grafana. This update introduces new features, important breaking changes, and enhancements to improve your experience. Below are the details of what's new and improved.
Breaking Changes
- Minimum Grafana Version: This release requires Grafana version 11.5 or higher. Please ensure your Grafana instance is updated before installing this version.
Added
- Kiosk Mode Support: Added support for kiosk mode to enable a distraction-free, full-screen experience. (#17)
- Hide Tooltip Option: Introduced an option to hide tooltips for a cleaner interface. (#42)
- LLM App Link Integration: Added integration with LLM applications, allowing seamless linking to AI-powered tools. (#45)
Changed
- Sticky Positioning Recalculation: Improved the recalculation of sticky positioning on window resize for better layout stability. (#42)
- Dynamic Menu Font Size: Updated the font size of dynamic menus to enhance readability and adaptability across devices. (#42)
[1.4.0] - 2025-06-02
Added
- Introduced the ability to customize the alignment of links, along with highlighting the currently selected dashboard for improved user experience. (#34)
- Added support for dynamic font sizing to enhance readability and adaptability across different devices and screen sizes. (#39)
- Implemented support for custom icons to allow users to personalize the visual representation of links and dashboards. (#36)
[1.3.0] - 2025-05-28
Added
- Added icons to the editor component for enhanced visual feedback (#19).
- Introduced horizontal and vertical layout options for improved customization and flexibility (#21).
- Added support for a Time-Picker input type to facilitate time-based interactions (#23).
- Implemented an HTML delimiter type for better content formatting and separation (#28).
- Added an option to highlight the current time picker for improved visibility and user experience (#29).
- Introduced a button row type for dropdown menus to enhance user interaction and accessibility (#30).
- Added a feature to freeze the panel on scroll for better usability in long dashboards (#31).
- Implemented end-to-end (E2E) testing to ensure reliability and stability (#35).
Changed
- Upgraded to Grafana 12.0 with updated dependencies for improved compatibility and performance (#24).
[1.2.1] - 2025-04-29
Changed
- Reverted the
swc/core
package to a previous version to resolve compatibility issues (#15).
[1.2.0] - 2025-04-27
Added
- Added an option to specify the menu position for greater UI flexibility and customization (#8).
- Included a community signature to acknowledge contributions and branding (#10).
Changed
- Upgraded to Grafana 11.6 with updated dependencies for enhanced stability and new features.
[1.1.0] - 2025-04-22
Added
- Added an option to sort tabs and prioritize selected tabs first for improved navigation (#6).
- Introduced a feature to highlight the current dashboard or link for better user focus and clarity (#4).
- Added support for displaying dropdown menus on hover instead of click for faster access and interaction (#3).
[1.0.0] - 2025-04-17
Added
- Initial release of the Business Links panel, built using Volkov Labs templates for a robust and scalable foundation.
