Plugins 〉Streamr
Dependencies
Grafana
Developer
Last updated
Learn how to leverage new AI features and observability tools, attend technical deep dives, & leave with tips for growing your observability strategy.
Sign up to save the date
Bring your crew,
save up to 20%
Don't miss out—Be the first to dive into Grafana 12, Prometheus 3.0, and our nearly sold-out hands-on labs on Grafana as Code, OpenTelemetry, and more.
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Streamr
- Overview
- Installation
- Change log
- Related content
Streamr data source
Streamr data source plugin for Grafana
Beam any Streamr stream to Grafana. Configure and visualize streamed data.
Features
- Any permission-granted Streamr stream as data source
- Stream ID optional on plugin settings, can be defined as query
- Detection of field types *
- Data source health check on save
Installation
- Go to
Configuration→Data Sources - Click
Add data soruce - Select
Streamras data source - Enter
Private KeyandStream ID(optional) - Click
Save & Test
From now on Streamr can be selected as data source:
- Go to
Dashboard→New panel - Select
StreamrasQuerysource
Notes
- Streamr field types aren't compatible to Grafana field types
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Streamr on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Streamr from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Changelog
1.5.0 (2021-05-03)
- Resend data points based on Grafana dashboard time range
1.4.0 (2021-03-26)
- Signed version
1.3.0 (2021-03-11)
- Stream ID as query param
- Code refactoring
1.2.2 (2021-02-05)
- Add screenshots
1.2.1 (2021-02-05)
- Remove versioning from
release.yml
1.2.0 (2021-02-05)
- Add
ci.ymlandrelease.yml
1.1.0 (2021-02-05)
- Move
privateKeytosecureJsonData - Add handling for
sessionToken - Add
tryCatchto Streamr response - Add
grafanaDependencytoplugin.json
1.0.0 (2021-02-04)
- Initial release
