Plugins 〉Sumo Logic
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Sumo Logic
- Overview
- Installation
- Change log
- Documentation →
Instantly visualize Sumo Logic data in Grafana
The Sumo Logic data source plugin is the easiest way to pull Sumo Logic data directly into Grafana dashboards.
- Visualize it either in isolation (one database) or blend it with other data sources.
- Discover correlations and covariances across all your data in minutes.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Sumo Logic on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Sumo Logic from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v1.6.8 - 2025-02-11
- ⚙️ Chore: Update backend dependencies
v1.6.7 - 2025-02-04
- ⚙️ Chore: Update frontend dependencies
v1.6.6 - 2025-01-17
- 🧪 Tests: Migrate e2e tests to Playwright
v1.6.5 - 2025-01-10
v1.6.4 - 2024-12-18
v1.6.3 - 2024-12-16
v1.6.2 - 2024-11-12
- ⚙️ Chore: Updated backend dependencies
v1.6.1 - 2024-10-28
v1.6.0 - 2024-10-25
- 🚀 Feature: Pass cookies with requests to avoid refused connections
v1.5.0 - 2024-10-24
- 🚀 Feature: Add configuration option for polling interval
v1.4.8 - 2024-10-24
- 📝 Documentation: Update docs
v1.4.7 - 2024-10-23
v1.4.6 - 2024-10-22
- ⚙️ Chore: Plugin can now recover from panic errors more gracefully
v1.4.5 - 2024-10-03
- ⚙️ Chore: Minimal supported Grafana version is now
10.4.8
v1.4.4 - 2024-09-23
v1.4.3 - 2024-09-12
v1.4.2 - 2024-08-30
- ⚙️ Chore: update backend dependencies
v1.4.1 - 2024-07-25
- 🐛 Fix: Make
DimensionsQueryRequest
return fetch error
v1.4.0 - 2024-06-25
- ⚙️ Chore: Added SLO metrics to the plugin
v1.3.0 - 2024-06-19
v1.2.0 - 2024-05-09
- 🐛 Fix: Fix loading custom API url from provisioning files
- ⚙️ Chore: Update backend libraries
v1.1.0 - 2024-03-28
- 🐛 Fix: Fix respecting timeouts.
v1.0.2 - 2024-03-13
- ⚙️ Chore: Backend binaries are now compiled with Go version
1.22.1
v1.0.1 - 2024-03-01
v1.0.0 - 2024-01-22
- 🚀 Feature Metric query builder
v0.2.0
- 🐛 Fix Fix displaying logs on all grafana versions 9+
- ⚙️ Chore Update frontend and backend dependencies
- ⚙️ Chore Bump min Grafana and NodeJS versions
v0.1.1
- ⚙️ Chore Update frontend dependencies
- 🐛 Fix Fix docs link
v0.1.0-beta.1
- 🚀 Feature Initial version
