Plugins ใ€‰Jira
Developer
Grafana Labs
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
grafana
Enterprise
Jira
Documentation โ†’
How to configure the JIRA plugin
Instantly visualize Jira data in Grafana
The Jira data source plugin is the easiest way to pull Jira data directly into Grafana dashboards.
  • Visualize it either in isolation (one database) or blend it with other data sources.
  • Discover correlations and covariances across all your data in minutes.
Installing Jira on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Jira from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
v2.1.2 - 2025-07-09
  • โš™๏ธ Chore: Improve logging
v2.1.1 - 2025-07-08
v2.1.0 - 2025-06-30
  • ๐Ÿ› Fix: Handle cascading select fields properly
  • โš™๏ธ Chore: Update backend dependencies
v2.0.0 - 2025-05-20
  • โš™๏ธ Chore: Switch to v3 API as the older versions are being deprecated
  • ๐Ÿš€ Feature: Support all custom fields
v1.12.0 - 2025-05-12
  • โš™๏ธ Chore: Improve configuration error handling
v1.11.8 - 2025-03-25
v1.11.7 - 2025-02-17
  • โš™๏ธ Chore: Improve error logging
v1.11.6 - 2025-02-11
v1.11.5 - 2025-02-04
  • โš™๏ธ Chore: Update frontend dependencies
v1.11.4 - 2025-01-10
v1.11.3 - 2025-01-08
  • โš™๏ธ Chore: Remove deprecated error source imports and fix incorrect error source for non-json content error
v1.11.2 - 2024-12-18
v1.11.1 - 2024-12-16
v1.11.0 - 2024-11-28
  • โš™๏ธ Chore: Bump backend dependencies
v1.10.8 - 2024-11-22
  • โš™๏ธ Chore: Update dependencies
v1.10.7 - 2024-11-12
  • โš™๏ธ Chore: Updated backend dependencies
v1.10.6 - 2024-11-05
  • ๐Ÿงช Tests: migrate e2e tests to @grafana/plugin-e2e
v1.10.5 - 2024-10-10
  • ๐Ÿ› Fix: Fix health check error messages
v1.10.4 - 2024-10-03
  • โš™๏ธ Chore: Minimal supported Grafana version is now 10.4.8
v1.10.3 - 2024-09-23
v1.10.2 - 2024-09-02
  • ๐Ÿ› Fix: Fix enterprise query caching not working
v1.10.1 - 2024-08-30
  • โš™๏ธ Chore: update backend dependencies
v1.10.0 - 2024-08-21
  • handle html responses gracefully + update backend dependencies
v1.9.8 - 2024-08-19
  • โš™๏ธ Chore: handle 401 error source correctly
v1.9.7 - 2024-07-24
  • โš™๏ธ Chore: add errorsource to jira plugin
v1.9.6 - 2024-07-01
v1.9.5 - 2024-05-29
v1.9.4 - 2024-04-12
  • ๐Ÿ› Fix: fix status category field to populate correctly in results
v1.9.3 - 2024-04-05
  • ๐Ÿ› Fix: Fix broken PDC
v1.9.2 - 2024-03-25
  • ๐Ÿ› Fix: Fix issue with plugin failing when querying "Key" field only
v1.9.1 - 2024-03-13
  • โš™๏ธ Chore: Backend binaries are now compiled with Go version 1.22.1
v1.9.0 - 2024-02-20
  • โš™๏ธ Chore: Add error source to responses
v1.8.1 - 2023-11-21
  • ๐Ÿ“ Documentation: Update documentation
v1.8.0 - 2023-10-26
  • โš™๏ธ Chore: Update backend and frontend dependencies
  • โš™๏ธ Chore: Minimum required Grafana runtime version is now 9.5.13
v1.7.2 - 2023-08-24
  • โš™๏ธ Chore: grafana backend plugin sdk updated to v0.171.0
v1.7.1 - 2023-07-27
  • โš™๏ธ Chore: grafana backend plugin sdk updated to v0.170.0
v1.7.0 - 2023-06-29
  • ๐Ÿš€ Feature: Added support for selecting additional fields (including JSON fields). Use transformations to extract values from JSON fields.
v1.6.1 - 2023-06-08
  • โš™๏ธ Chore: backend libs updated with golang:1.20.5
v1.6.0 - 2023-05-22
  • ๐Ÿš€ Feature: UI improvements to configuration page
v1.5.0 - 2023-05-10
v1.4.1 - 2023-05-05
  • ๐Ÿ› Fix: Fixed bug where query parameters were ignored when running query (bug appeared in 1.4.0)
v1.4.0 - 2023-05-03
BROKEN, USE 1.4.1+ INSTEAD
  • ๐Ÿš€ Feature: Made internal improvements to reduce request time (re-adding of the selected fields needed to see the improvement)
  • โš™๏ธ Chore: Backend binaries are now compiled with Go 1.20.4
v1.3.0 - 2023-04-18
  • ๐Ÿš€ Feature: Small improvements to the config page (fixed tooltip, UI improvements, etc.)
v1.2.0 - 2023-03-22
  • ๐Ÿš€ Feature: Made improvements to the config page usability
  • ๐Ÿš€ Feature: Updated "Run query" button style and position in the query editor
  • ๐Ÿš€ Feature: Started showing JQL errors in the query editor
v1.1.0 - 2023-02-01
  • โš™๏ธ Chore: Internal frontend dependencies updated
  • โš™๏ธ Chore: Minimum required Grafana runtime version is now 8.4.7
v1.0.11 - 2022-12-13
  • โš™๏ธ Chore: Backend binaries are now compiled with Go 1.19.4
  • โš™๏ธ Chore: Grafana backend plugin SDK updated to v0.145.0
  • โš™๏ธ Chore: Backend third party dependencies updated
v1.0.10 - 2022-11-04
  • โš™๏ธ Chore: Backend binaries compiled with latest go version 1.19.3
v1.0.9 - 2022-09-26
  • Fixed an issue with logger
v1.0.8 - 2022-07-19
  • Over 100 issues can be queried now
v1.0.7 - 2022-03-20
  • Entering a user in settings is now optional
v1.0.6 - 2022-03-15
  • Updated documentation
v1.0.5 - 2022-01-06
  • Update sdk: individual license, instance manager, debugger
v1.0.4 - 2021-12-10
  • Add debug logger
v1.0.3 - 2021-11-18
  • Fixes for inconsistent run query button behavior
v1.0.2 - 2021-06-08
  • Fixes Grafana v8 field loading issue
v1.0.1 - 2021-04-07
  • Update grafana-enterprise-sdk
v1.0.0 - 2021-03-31
  • Official plugin release
v0.9.7 - 2021-03-11
  • Query type is now being set when selecting the Jira data source
v0.9.6 - 2021-02-26
  • ๐Ÿš€ Feature: Add Jira Server support
  • ๐Ÿš€ Feature: Add Limit setting for Issues query
v0.9.5 - 2021-01-15
  • <nil> and [] are no longer displayed when there is no data to display in a field
  • Fields that do not have a converter no longer show up in list of selectable fields
  • Added tooltips
  • User Display Name will not just be User Name
  • Added support for more fields
    • Status
    • Labels
    • Components
    • Resolution
    • Priority
    • Due Date
    • Votes
    • User (not in arrays)
    • Version
    • Parent
    • Sub Tasks
    • All options fields
    • Any
    • FixVersions
    • AffectsVersions
    • Rank
    • Epic Link
    • Epic Status
v0.9.4 - 2021-01-11
  • Added supported Jira types
    • Any
    • Approval
    • Array
    • Date
    • Feed Back
    • Number
    • Option
    • Project
    • Sprint
    • String
    • User
  • Added support for expanding Jira types so they can be selected in the field selector, for example Sprint object becomes Sprint Name, Sprint Start Date and so on
v0.9.0 - 2021-01-06
  • Beta release
