Plugins 〉Wavefront
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Wavefront
- Overview
- Installation
- Change log
- Documentation →
Instantly visualize Wavefront data in Grafana
The Wavefront data source plugin is the easiest way to pull Wavefront data directly into Grafana dashboards.
- Visualize it either in isolation (one database) or blend it with other data sources.
- Discover correlations and covariances across all your data in minutes.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Wavefront on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Wavefront from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
v2.5.13 - 2025-02-20
- ⚙️ Chore: Improve error tracking
v2.5.12 - 2025-02-17
- ⚙️ Chore: Improve error logging
v2.5.11 - 2025-02-11
- 🧪 Tests: Migrate e2e tests to Playwright
v2.5.10 - 2025-02-11
- ⚙️ Chore: Update backend dependencies
v2.5.9 - 2025-02-04
- ⚙️ Chore: Update frontend dependencies
v2.5.8 - 2025-01-10
v2.5.7 - 2024-12-18
v2.5.6 - 2024-12-16
v2.5.5 - 2024-11-19
- ⚙️ Chore: Replace error source http client with a new error source method
v2.5.4 - 2024-11-12
- ⚙️ Chore: Updated backend dependencies
v2.5.3 - 2024-10-03
- ⚙️ Chore: Minimal supported Grafana version is now
10.4.8
v2.5.2 - 2024-09-23
v2.5.1 - 2024-08-30
- ⚙️ Chore: update backend dependencies
v2.5.0 - 2024-07-25
- ⚙️ Chore: Capture error source
v2.4.0 - 2024-07-03
- ⚙️ Chore: Added SLO metrics to the plugin
v2.3.0 - 2024-06-19
- ⚙️ Chore: update dep and sdk license check
v2.2.4 - 2024-06-19
v2.2.3 - 2024-03-13
- ⚙️ Chore: Backend binaries are now compiled with Go version
1.22.1
v2.2.2 - 2024-03-04
- ⚙️ Chore: Update dependencies
v2.2.2 - 2023-11-30
- ⚙️ Chore: Update sdk version to capture error source
v2.2.1 - 2023-11-21
v2.2.0 - 2023-10-30
- ⚙️ Chore: Update backend and frontend dependencies
9.5.13
v2.1.6 - 2023-10-20
v2.1.5 - 2023-10-09
v2.1.4 - 2023-09-27
- 🐛 Fix: Avoid panic when setting up instance
v2.1.3 - 2023-09-26
- ⚙️ Chore: migrate to create-plugin
v2.1.2 - 2023-08-24
- 📝 Documentation: Update customer requirement copy
- ⚙️ Chore: Grafana backend plugin sdk updated to
v0.171.0
v2.1.1 - 2023-06-08
- ⚙️ Chore: backend libs updated with golang:1.20.5
v2.1.0 - 2023-05-26
- 🚀 Feature: Secure socks proxy support added
- ⚙️ Chore: Minimum required grafana runtime changed to 8.4.7
- ⚙️ Chore: Updated backend plugin SDK
v2.0.3 - 2023-05-03
- ⚙️ Chore: Backend binaries are now compiled with golang 1.20.4
v2.0.2 - 2023-04-19
- ⚙️ Chore: Backend binaries are now compiled with golang 1.20.3
v2.0.1 - 2022-12-13
- ⚙️ Chore: Backend binaries are now compiled with Go 1.19.4
- ⚙️ Chore: Grafana backend plugin SDK updated to v0.145.0
- ⚙️ Chore: Grafana enterprise SDK updated to latest to fix licensing issues
- ⚙️ Chore: Backend third party dependencies updated
v2.0.0 - 2022-04-04
- Events query type added
- Ability to specify the queryType when running a raw query. (HYBRID/WQL/PROMQL)
- New annotation editor allows custom fields mapping
- UX update for variable query editor
- BREAKING: Fields for the exiting wavefront annotations queries have to be manually selected in the annotation editor
- BREAKING: When specifying queryType in raw query editor, query will not automatically unescape. Example: If you have
%28
in your query, you need to convert that into corresponding character(
v1.1.1 - 2022-03-29
- Build with go 1.18 to address CVE-2022-24921
v1.1.0 - 2022-03-15
- Support for enabling the HTTP logger debugging tool
v1.0.11 - 2021-12-17
- Enterprise license check update
v1.0.10 - 2021-09-28
- Support custom timeout configuration
- Capture error and warnings from wavefront response
v1.0.9 - 2021-08-24
- 🐛 Fix: use "strict" Wavefront API param to limit returned time range
v1.0.8 - 2021-07-12
- 🐛 Fix: fixed an issue where results were returned outside of the selected time range
v1.0.7 - 2021-06-23
- 🐛 Fix: fixed a bug where hiding/disabling queries doesn't work
v1.0.6 - 2021-04-21
- 🐛 Fix: matchingSourceTags now include host tags
v1.0.5 - 2021-04-12
- ⚙️ Chore: Update SDK
v1.0.4 - 2020-10-30
- Update dashboards
v1.0.3 - 2020-10-28
- Support multi-value variables
- Allow spaces in queries (url encode)
v1.0.2 - 2020-10-01
- Add default dashboards
- Update Readme with an overview, and add screenshots
v1.0.1 - 2020-09-16
- 🐛 Fix: Not showing all metrics
- 🐛 Fix: Handle Meta undefined error
v1.0.0 - 2020-09-10
- Initial release
