Plugins 〉Salesforce
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Salesforce
- Overview
- Installation
- Change log
- Documentation →
Instantly visualize Salesforce data in Grafana
The Salesforce data source plugin is the easiest way to pull Salesforce data directly into Grafana dashboards.
- Visualize it either in isolation (one database) or blend it with other data sources.
- Discover correlations and covariances across all your data in minutes.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Salesforce on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Salesforce from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v1.7.12 - 2025-02-17
- ⚙️ Chore: Improve error logging
v1.7.11 - 2025-02-17
v1.7.10 - 2025-02-11
- ⚙️ Chore: Update backend dependencies
v1.7.9 - 2025-02-04
- ⚙️ Chore: Update frontend dependencies
v1.7.8 - 2025-01-10
v1.7.7 - 2024-12-18
v1.7.6 - 2024-12-16
v1.7.5 - 2024-11-22
- ⚙️ Chore: Update dependencies
v1.7.4 - 2024-11-12
- ⚙️ Chore: Updated backend dependencies
v1.7.3 - 2024-10-03
- ⚙️ Chore: Minimal supported Grafana version is now
10.4.8
v1.7.2 - 2024-09-23
v1.7.1 - 2024-08-30
- ⚙️ Chore: update backend dependencies
v1.7.0 - 2024-07-15
- ⚙️ Chore: Capture error source
v1.6.0 - 2024-06-14
- ⚙️ Chore: Added SLO metrics to the plugin
v1.5.0 - 2024-06-05
v1.4.0 - 2024-03-14
v1.3.3 - 2024-03-13
- ⚙️ Chore: Backend binaries are now compiled with Go version
1.22.1
v1.3.2 - 2024-02-29
- 🐛 Fix: 401 Authentication error
v1.3.1 - 2023-11-08
- 🐛 Fix: Fix for broken JWT authentication. Previously instances with JWT authentication were failing with
invalid_grant
error
v1.3.0 - 2023-11-06
9.5.13
- ⚙️ Chore: Frontend dependencies updated
- ⚙️ Chore: Backend dependencies updated
- 🐛 Fix: Updated display name for the results column
v1.2.0 - 2023-08-21
- ⚙️ Chore: Plugin now explicitly sets the min TLS required version to tls 1.2
v1.1.2 - 2023-06-28
- ⚙️ Chore: move to community maintained version of jwt-go
v1.1.1 - 2023-06-08
- ⚙️ Chore: backend libs updated with golang:1.20.5
v1.1.0 - 2023-05-18
- 🚀 Feature: Secure socks proxy support added
v1.0.11 - 2023-05-16
- 🐛 Fix: (Config Editor) Fixed a minor UI bug where fields are not stored correctly when used with JWT auth
- 🐛 Fix: (Config Editor) Fixed a minor UI bug where download certificate button wasn't working correctly when used with the JWT auth
v1.0.10 - 2023-05-04
- ⚙️ Chore: Backend binaries compiled with latest go version 1.20.4
- ⚙️ Chore: Grafana plugin SDK (
grafana/grafana-plugin-sdk-go
) updated fromv0.159.0
tov0.161.0
v1.0.9 - 2023-04-17
- ⚙️ Chore: Backend binaries compiled with latest go version 1.20.3
v1.0.8 - 2023-03-19
- Config Editor - Improved healthcheck error messages
v1.0.7 - 2023-02-28
- ⚙️ Chore: Backend binaries compiled with latest go version 1.19.6
- 🐛 Fix: (Config Editor) Fixed a bug where editors were incorrectly determining auth type when used with provisioning
v1.0.6 - 2022-11-02
- ⚙️ Chore: Backend binaries compiled with latest go version 1.19.4
- ⚙️ Chore: Backend Grafana dependencies updated to latest version
v1.0.5 - 2022-11-02
- ⚙️ Chore: Backend binaries compiled with latest go version 1.19.3
v1.0.4 - 2022-10-28
- ⚙️ Chore: Backend binaries compiled with latest go version 1.19.2
- ⚙️ Chore: Backend grafana plugin SDK updated to latest
- ⚙️ Chore: Frontend grafana dependencies updated
- ⚙️ Chore: Minimum required grafana runtime updated to 8.4.7
- 📝 Documentation: Typo errors fixed
v1.0.3 - 2022-03-02
- 🐛 Fix: Ensure http connections are reused
v1.0.2 - 2022-02-25
- 🐛 Fix: Ensure http connections are closed
v1.0.1 - 2022-01-07
- ⚙️ Chore: Individual License Check
v1.0.0 - 2021-09-09
- Support JWT Authentication
v0.12.0 - 2021-08-18
- Reports
v0.11.0 - 2021-08-06
- SOQL Builder
v0.10.0 - 2021-07-30
- Fixed a bug where incorrect auth URL used for non sandbox accounts.
- In config, Password and Security token now captured separately.
- Improved error messages in healthcheck config
v0.9.3 - 2021-07-08
- 🚀 Feature: Macros for Quarter Start/End
v0.9.2 - 2021-06-23
- 🐛 Fix: Parent-to-child (one to many) relationship queries
v0.9.1 - 2021-06-16
- 🚀 Feature: Query Editor Suggestions
v0.9.0 - 2021-06-07
- Beta release
