Plugins 〉Jira
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Jira
- Overview
- Installation
- Change log
- Documentation →
How to configure the JIRA plugin
Instantly visualize Jira data in Grafana
The Jira data source plugin is the easiest way to pull Jira data directly into Grafana dashboards.
- Visualize it either in isolation (one database) or blend it with other data sources.
- Discover correlations and covariances across all your data in minutes.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Jira on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Jira from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
v1.11.7 - 2025-02-17
- ⚙️ Chore: Improve error logging
v1.11.6 - 2025-02-11
- ⚙️ Chore: Update backend dependencies
v1.11.5 - 2025-02-04
- ⚙️ Chore: Update frontend dependencies
v1.11.4 - 2025-01-10
v1.11.3 - 2025-01-08
- ⚙️ Chore: Remove deprecated error source imports and fix incorrect error source for non-json content error
v1.11.2 - 2024-12-18
v1.11.1 - 2024-12-16
v1.11.0 - 2024-11-28
- ⚙️ Chore: Bump backend dependencies
v1.10.8 - 2024-11-22
- ⚙️ Chore: Update dependencies
v1.10.7 - 2024-11-12
- ⚙️ Chore: Updated backend dependencies
v1.10.6 - 2024-11-05
- 🧪 Tests: migrate e2e tests to
@grafana/plugin-e2e
v1.10.5 - 2024-10-10
- 🐛 Fix: Fix health check error messages
v1.10.4 - 2024-10-03
- ⚙️ Chore: Minimal supported Grafana version is now
10.4.8
v1.10.3 - 2024-09-23
v1.10.2 - 2024-09-02
- 🐛 Fix: Fix enterprise query caching not working
v1.10.1 - 2024-08-30
- ⚙️ Chore: update backend dependencies
v1.10.0 - 2024-08-21
- handle html responses gracefully + update backend dependencies
v1.9.8 - 2024-08-19
- ⚙️ Chore: handle 401 error source correctly
v1.9.7 - 2024-07-24
- ⚙️ Chore: add errorsource to jira plugin
v1.9.6 - 2024-07-01
v1.9.5 - 2024-05-29
v1.9.4 - 2024-04-12
- 🐛 Fix: fix status category field to populate correctly in results
v1.9.3 - 2024-04-05
- 🐛 Fix: Fix broken PDC
v1.9.2 - 2024-03-25
- 🐛 Fix: Fix issue with plugin failing when querying "Key" field only
v1.9.1 - 2024-03-13
- ⚙️ Chore: Backend binaries are now compiled with Go version
1.22.1
v1.9.0 - 2024-02-20
- ⚙️ Chore: Add error source to responses
v1.8.1 - 2023-11-21
- 📝 Documentation: Update documentation
v1.8.0 - 2023-10-26
- ⚙️ Chore: Update backend and frontend dependencies
- ⚙️ Chore: Minimum required Grafana runtime version is now 9.5.13
v1.7.2 - 2023-08-24
- ⚙️ Chore: grafana backend plugin sdk updated to
v0.171.0
v1.7.1 - 2023-07-27
v0.170.0
v1.7.0 - 2023-06-29
- 🚀 Feature: Added support for selecting additional fields (including JSON fields). Use transformations to extract values from JSON fields.
v1.6.1 - 2023-06-08
- ⚙️ Chore: backend libs updated with golang:1.20.5
v1.6.0 - 2023-05-22
- 🚀 Feature: UI improvements to configuration page
v1.5.0 - 2023-05-10
- 🚀 Feature: Secure socks proxy support added
v1.4.1 - 2023-05-05
- 🐛 Fix: Fixed bug where query parameters were ignored when running query (bug appeared in
1.4.0
v1.4.0 - 2023-05-03
BROKEN, USE 1.4.1+
INSTEAD
- 🚀 Feature: Made internal improvements to reduce request time (re-adding of the selected fields needed to see the improvement)
- ⚙️ Chore: Backend binaries are now compiled with Go 1.20.4
v1.3.0 - 2023-04-18
- 🚀 Feature: Small improvements to the config page (fixed tooltip, UI improvements, etc.)
v1.2.0 - 2023-03-22
- 🚀 Feature: Made improvements to the config page usability
- 🚀 Feature: Updated "Run query" button style and position in the query editor
- 🚀 Feature: Started showing JQL errors in the query editor
v1.1.0 - 2023-02-01
- ⚙️ Chore: Internal frontend dependencies updated
- ⚙️ Chore: Minimum required Grafana runtime version is now 8.4.7
v1.0.11 - 2022-12-13
- ⚙️ Chore: Backend binaries are now compiled with Go 1.19.4
- ⚙️ Chore: Grafana backend plugin SDK updated to v0.145.0
- ⚙️ Chore: Backend third party dependencies updated
v1.0.10 - 2022-11-04
- ⚙️ Chore: Backend binaries compiled with latest go version 1.19.3
v1.0.9 - 2022-09-26
- Fixed an issue with logger
v1.0.8 - 2022-07-19
- Over 100 issues can be queried now
v1.0.7 - 2022-03-20
- Entering a user in settings is now optional
v1.0.6 - 2022-03-15
- Updated documentation
v1.0.5 - 2022-01-06
- Update sdk: individual license, instance manager, debugger
v1.0.4 - 2021-12-10
- Add debug logger
v1.0.3 - 2021-11-18
- Fixes for inconsistent run query button behavior
v1.0.2 - 2021-06-08
- Fixes Grafana v8 field loading issue
v1.0.1 - 2021-04-07
- Update grafana-enterprise-sdk
v1.0.0 - 2021-03-31
- Official plugin release
v0.9.7 - 2021-03-11
- Query type is now being set when selecting the Jira data source
v0.9.6 - 2021-02-26
- 🚀 Feature: Add Jira Server support
- 🚀 Feature: Add Limit setting for Issues query
v0.9.5 - 2021-01-15
<nil>
and[]
are no longer displayed when there is no data to display in a field- Fields that do not have a converter no longer show up in list of selectable fields
- Added tooltips
- User Display Name will not just be User Name
- Added support for more fields
- Status
- Labels
- Components
- Resolution
- Priority
- Due Date
- Votes
- User (not in arrays)
- Version
- Parent
- Sub Tasks
- All options fields
- Any
- FixVersions
- AffectsVersions
- Rank
- Epic Link
- Epic Status
v0.9.4 - 2021-01-11
- Added supported Jira types
- Any
- Approval
- Array
- Date
- Feed Back
- Number
- Option
- Project
- Sprint
- String
- User
- Added support for expanding Jira types so they can be selected in the field selector, for example Sprint object becomes Sprint Name, Sprint Start Date and so on
v0.9.0 - 2021-01-06
- Beta release
