Plugins 〉GitLab
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
GitLab
- Overview
- Installation
- Change log
- Documentation →
Instantly visualize GitLab data in Grafana
The GitLab data source plugin is the easiest way to pull GitLab data directly into Grafana dashboards.
- Visualize it either in isolation (one database) or blend it with other data sources.
- Discover correlations and covariances across all your data in minutes.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing GitLab on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install GitLab from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v2.3.13 - 2025-02-11
- ⚙️ Chore: Update backend dependencies
v2.3.12 - 2025-02-04
- ⚙️ Chore: Update frontend dependencies
v2.3.11 - 2025-01-20
- 🐛 Fix: Fix querying for merge requests
v2.3.10 - 2025-01-10
v2.3.9 - 2024-12-18
v2.3.8 - 2024-12-16
v2.3.7 - 2024-12-04
- ⚙️ Chore: Fix error source for empty access token
v2.3.6 - 2024-11-27
- 🧪 Tests: moving e2e tests to @grafana/plugins-e2e
v2.3.5 - 2024-11-12
- ⚙️ Chore: Updated backend dependencies
v2.3.4 - 2024-10-03
- ⚙️ Chore: Minimal supported Grafana version is now
10.4.8
v2.3.3 - 2024-09-23
v2.3.2 - 2024-08-30
- ⚙️ Chore: update backend dependencies
v2.3.1 - 2024-08-27
- 🐛 Fix: Fix dashboard variable displayName
v2.3.0 - 2024-08-20
- 🚀 Feature: Apply dashboard timerange to Merge Request query type and increase page size to retrieve more rows in its query
v2.2.1 - 2024-08-15
- 🐛 Fix: Retrieve all merge requests in its query
v2.2.0 - 2024-07-05
- 🐛 Fix: Fix page limit config setting
- ⚙️ Chore: Rewrite variable editor to the new architecture
v2.1.0 - 2024-07-01
- ⚙️ Chore: Added SLO metrics to the plugin
v2.0.0 - 2024-06-19
- ⚙️ Chore: Simplify plugin's architecture
- BREAKING CHANGE: This release includes a breaking change for PROJECTS returned fields.
public
field has been removed andpublic_builds
are nowpublic_jobs
according to the GitLab API. Any queries that leverage tags will need to be updated manually.
v1.8.1 - 2024-04-05
- 🐛 Fix: Fix broken PDC
v1.8.0 - 2024-03-22
- 🐛 Fix: Fix fetching deployments.
v1.7.2 - 2024-03-13
- ⚙️ Chore: Backend binaries are now compiled with Go version
1.22.1
v1.7.1 - 2024-01-24
v1.7.0 - 2024-01-17
- ⚙️ Chore: Add error source to returned queries
v1.6.0 - 2023-12-01
- ⚙️ Chore: Fix security vulnerabilities, update backend and frontend packages
v1.5.1 - 2023-10-12
- 🐛 Fix: add dates that are not truncated in pipelines query
v1.5.0 - 2023-07-11
- ⚙️ Chore: Grafana 10 plug-in overhaul
v1.4.1 - 2023-06-08
- ⚙️ Chore: backend libs updated with golang:1.20.5
v1.4.0 - 2023-05-30
- 🚀 Feature: Secure socks proxy support added
v1.3.2 - 2023-05-04
golang:1.20.4
which contains security fixes - ⚙️ Chore: Backend grafana SDK dependencies are updated
v1.3.1 - 2023-04-19
golang:1.20.3
v1.3.0 - 2023-03-16
- 🚀 Feature: enable alerting
v1.2.0 - 2023-02-06
- 🚀 Feature: Update error messages and tooltips
- ⚙️ Chore: Update internal frontend dependencies
- ⚙️ Chore: Update e2e tests
v1.1.0 - 2023-01-06
- 🚀 Feature: Start using default behavior for annotations (with extended query types and range support)
v1.0.2 - 2022-12-15
- ⚙️ Chore: Backend binaries compiled with latest go version 1.19.4
- ⚙️ Chore: Backend enterprise-sdk updated
v1.0.1 - 2022-11-07
- 🐛 Fix: Settings URL is now used instead of default URL
- ⚙️ Chore: Backend binaries compiled with latest go version 1.19.3
v1.0.0 - 2022-10-25
- 🚀 Feature: Add support for audit events, users, merge request approvals, field tags, and environments
- ⚙️ Chore: Update grafana dependencies to 8.4.7
- ⚙️ Chore: Backend compiled with latest go version 1.19.2
v0.2.0 - 2022-01-10
- 🚀 Feature: Add support for query merge requests and pipelines
v0.1.5 - 2022-01-10
- ⚙️ Chore: Update Licensing
v0.1.3 - 2021-04-12
- ⚙️ Chore: Update SDK
v0.1.2 - 2021-02-19
Features
- Query resources: Adds support for querying multiple GitLab API resources: projects, commits, issues, releases, deployments and labels.
- Template variables: Adds support for creating query template variables based on the available GitLab API resources.
- Annotations: Adds support for creating annotations based on the available GitLab API events: commits, issues, releases, deployments and environments.
