LDAP DB monitor
Monitor your db suffixes!
You want to monitor the 389 Directory Server DBs activity and load. Please download and compile the ds389 input plugin, now in beta version at Github.
- Create your telegraf config file, with many LDAP instances tags as your need.
- Test the plugin to ensure you are collecting the data as explained in the plugin README
- Then install this dashboard and enjoy!
PS: the alert section still has to improve.
The plugin is still waiting to be added to Telegraf. Meanwhile you can add it as external here.
Azure Cosmos DB
