Documentation tooling and workflows
This section provides an overview of the documentation tools we use at Grafana and highlights some of the key processes we use to create documentation.
Using git
This document explains how to use the git
command line tool to contribute changes to a Grafana Labs repository.
If you are unfamiliar with git
, refer to The Git & Github Bootcamp or Git and GitHub for Writers.
Although processes for contributing changes to a repository differ for each repository, at Grafana there is a generally consistent workflow defined below.
Creating a local repository
Creating a local repository is only necessary when first contributing to a new repository.
To create a local repository from a remote repository, use git clone
with the URL of the repository.
There are two types of URL used for cloning: SSH and HTTPS. Using SSH URLs means that you don’t have to provide a username and personal access token when pushing commits. Instead, authentication with for URLs uses an SSH key. To set up SSH key authentication in GitHub, refer to Adding a new SSH key to your GitHub account.
The SSH URL for a Grafana repository is git@github.com:grafana/<REPOSITORY>.git
For example, the SSH URL for the Grafana Mimir repository is git@github.com:grafana/mimir.git
Cloning a repository creates a directory containing a git repository and a configured git remote named origin
that refers to the remote repository.
To clone the Grafana Mimir repository, for example:
git clone git@github.com:grafana/mimir.git
The output is similar to the following:
Cloning into 'mimir'...
remote: Enumerating objects: 111551, done.
remote: Counting objects: 100% (12447/12447), done.
remote: Compressing objects: 100% (3830/3830), done.
remote: Total 111551 (delta 9389), reused 10865 (delta 8511), pack-reused 99104
Receiving objects: 100% (111551/111551), 101.82 MiB | 3.50 MiB/s, done.
Resolving deltas: 100% (73091/73091), done.
You can then enter the repository by changing to the newly created directory.
cd mimir
For a full list of Grafana repositories, refer to Grafana Labs.
Downloading updated references from the remote repository
Before contributing changes to a new repository, it’s critical to have an up-to-date copy of the remote references so that your changes aren’t out of date.
To fetch the updated references from the remote repository, use git fetch
git fetch
If there are no updates, the command produces no output. If there are updates, the output is similar to the following:
comremote: Enumerating objects: 547, done.
remote: Counting objects: 100% (488/488), done.
remote: Compressing objects: 100% (128/128), done.
remote: Total 373 (delta 280), reused 328 (delta 242), pack-reused 0
Receiving objects: 100% (373/373), 156.38 KiB | 1.38 MiB/s, done.
Resolving deltas: 100% (280/280), completed with 79 local objects.
From github.com:grafana/mimir
659af75c3..321d1ae89 main -> origin/main
* [new branch] threaded-reader -> origin/threaded-reader
Creating a new branch from the main remote branch
By convention, the remote repository in GitHub is the source of truth for a repository’s history.
The main branch of a repository is typically called main
and occasionally called master
Note that we prefer to use inclusive language, so main
is the preferred name.
After fetching the latest changes to your local repository from the remote repository in GitHub, create a local branch to commit your changes. Working on your own branch separates and isolates your changes so that they can be later reviewed before incorporation into the main branch.
A branch name should be unique.
To create a new branch called my-branch
from the remote branch called main
git checkout -b my-branch origin/main
The output is the following:
branch 'my-branch' set up to track 'origin/main'.
Switched to a new branch 'my-branch'
You are now on a new local branch and can begin to commit changes. This means that you are now working on a branch you’ve created to reflect the changes you’re planning to make and can use this branch to develop your content and test different layouts/approaches/structures freely.
To check which branch you currently working on, use git branch
The command outputs a list of local branches with your current branch marked with an asterisk *
For example:
git branch
* my-branch
main
Indicating that you are on the branch my-branch
and there is another local branch named main
Alternatively, you can use git status
to check your current branch and understand the status of the branch.
Note:
git status
relies on your local repository having the up-to-date references from the remote repository. Rungit fetch
beforegit status
for the most accurate status.
To understand the output of git status
, refer to Git - git-status Documentation.
Committing changes to your branch
Committing changes has two steps: staging and committing. You can stage whole files and directories, or you can stage individual areas within files.
Staging files and directories
To stage whole files or directories, use git add <PATH...>
To stage the updated.md
file in your current working directory, for example:
git add updated.md
Stage all files relevant to your current change.
Staging individual areas within files
Diff hunks are individual areas of difference in files.
Each diff hunk shows one area where a file differs between versions.
You can interactively stage hunks using git add -p
git
presents you with a diff hunk for each change that you have made and asks if you would like to stage it.
Answering the prompt with y
stages the hunk.
Answering the prompt with n
skips staging the hunk.
Answering the prompt with q
skips staging the hunk and any remaining hunks.
Answering the prompt with a
stages the hunk and any remaining hunks.
Using the prompt, stage all hunks relevant to your current change.
Once you have staged your changes, you can commit them with git commit -s
git
opens your text editor where you can type a commit message.
Note: The
-s
flag adds aSigned-off-by
message to your commits that states you agree to the terms published at https://developercertificate.org/ for that particular commit. This is a requirement for a number of repositories.
The first line of a message is the subject. Commit subjects should be descriptive and concise and are typically written in the imperative, present tense. To provide additional information, leave a blank line after the subject and write a commit body. For example:
Use American English spellings
American English is preferred by our technical documentation style-guide.
For more information, refer to https://github.com/grafana/technical-documentation/tree/main/docs/sources/style-guide.
Finally, save and close the file opened by git
to finish the commit.
For small changes where you only need write a subject, use the -m
flag to provide the message without invoking your editor.
For example:
git commit -s -m "Use American English spellings"
Pushing changes to the remote repository
Pushing changes to the remote repository allows other people to look at your commits and review them. It’s also the first step in getting your changes incorporated into the main branch.
Push your changes using git push
To push your local branch called my-branch
to a remote branch of the same name:
git push -u origin my-branch
Enumerating objects: 14, done.
Counting objects: 100% (14/14), done.
Delta compression using up to 8 threads
Compressing objects: 100% (8/8), done.
Writing objects: 100% (10/10), 3.34 KiB | 3.34 MiB/s, done.
Total 10 (delta 5), reused 0 (delta 0), pack-reused 0
remote: Resolving deltas: 100% (5/5), completed with 3 local objects.
remote:
remote: Create a pull request for 'my-branch' on GitHub by visiting:
remote: https://github.com/grafana/technical-documentation/pull/new/my-branch
remote:
To github.com:grafana/technical-documentation.git
* [new branch] HEAD -> my-branch
branch 'my-branch' set up to track 'origin/my-branch'.
The response from GitHub includes a link used to open a pull request for your remote branch. Click the link to open GitHub, then click the green button on the upper left of the screen to open the pull request for reviewers. Here, you can also edit the title and further detail in the larger text box as well as add reviewers by clicking the Settings icon and entering reviewer GitHub usernames.
Merging changes from the main branch
Because git and GitHub are naturally collaborative, others are also making and merging pull requests at the same time as you. From the point where you created your branch and when you’re ready to merge the pull request, the main branch might have changed in significant ways, or even developed a conflict with your branch.
If the changes don’t conflict, you can use git to incorporate the changes made to the main branch with yours without making any additional changes.
First, fetch changes to all branches and remotes:
git fetch --all
Update your local copy of the main branch by merging the remote changes into it:
git switch main
git merge --ff-only
After switching branches, git also lets you know if your local copy needs updating (“Your branch is behind ‘origin/main’…”). The --ff-only
flag means “fast-forwarding”, which simply applies the changes to the end of your local copy because your local copy has no conflicting changes.
Switched to branch 'main'
Your branch is behind 'origin/main' by 30 commits, and can be fast-forwarded.
(use "git pull" to update your local branch)
Now switch back to your branch and merge the main branch into it, applying its changes into yours:
git switch my-branch
git merge main
If there are no changes to apply, git confirms this:
$ git merge main
Already up to date.
Otherwise, if successful, git outputs the changes being applied to your branch:
$ git merge main
Removing public/app/plugins/panel/geomap/utils/view.ts
Auto-merging .github/CODEOWNERS
Merge made by the 'recursive' strategy.
.betterer.results | 142 +--
.drone.yml | 351 ++++++-
.github/CODEOWNERS | 3 +
Resolving conflicts
GitHub and git both warn you when the source branch and your branch directly conflict.
GitHub notifies you in the pull request if your branch conflicts with the source branch. If the conflict is easy to resolve, GitHub offers to help you resolve it using the web editor. See its documentation for details.
If the conflict is too complex to resolve in the web editor, GitHub directs you to resolve it on the command line.
If there’s a conflict when attempting to merge the main branch into yours, git also tells you which files are in conflict:
$ git merge main
CONFLICT (content): Merge conflict in .github/CODEOWNERS
Automatic merge failed; fix conflicts and then commit the result.
GitHub also has detailed, cross-platform instructions for resolving a merge conflict using git on the command line. See its documentation for details.
