Menu
Oracle data source
Enterprise
Oracle data source
Oracle is a multi-model database management system. The Oracle data source plugin allows you to visualize data from Oracle in Grafana.
The following topics will help you get started working with Oracle and Grafana:
Requirements
The Oracle plugin has the following requirements:
- An Oracle instance with at least one user.
- Any free or paid Grafana Cloud plan or an activated on-prem Grafana Enterprise license. Contracted Cloud customers should refer to their agreement.
Known limitations
The following are known limitations:
- The Oracle plugin is not supported in ARM64 architecture (for example, M1/M2 Macbook)
- TNSNames and Kerberos are not currently supported in Grafana Cloud
Get the most out of the plugin
After installing and configuring the Oracle data source you can:
- add annotations
- configure and use templates and variables
- add transformations
- set up alerting
Was this page helpful?
Video
Unify your data with Grafana plugins: Datadog, Splunk, MongoDB, and more
In this webinar, learn how to leverage Grafana's plugin ecosystem for access to 80+ data sources, including plugins for Datadog, Splunk, MongoDB, and more.
Video
Grafana plugins demo: GitHub, GitLab, JIRA, ServiceNow, and more
In this webinar, we'll show you how to use Grafana to unlock these insights and have better visibility into the performance of your software development team.
Video
All about Grafana plugins: Visualizing disparate data sources in one place
Grafana Enterprise plugins are integrations with other commercial monitoring tools (such as Datadog, Splunk, New Relic, ServiceNow, Oracle, and Dynatrace) that are created, maintained, and supported by the Grafana Labs team.
