Icinga2 with Graphite
Icinga2 & Graphite Dashboard
Icinga2 Dashboard
This dashboard can be used with a default icinga2 installation. It will show different states about a host and its services. Including UP/DOWN state, load, disk space, process count and more. The intention of the dashboard is to be extended as your icinga2 configuration grows. It includes special values like thresholds and downtimes.
Icinga2 Graphite Feature
To enable the GraphiteWriter on your icinga2 installation, use the commandline:
icinga2 feature enable graphite
Configure your Graphite host in /etc/icinga2/features-enabled/graphite.conf:
object GraphiteWriter "graphite" {
host = "127.0.0.1"
port = 2003
Learn more about the GraphiteWriter in the Docs
Thresholds
Thresholds are not configured in graph panels, but retreived from icinga2. It helps you to find alerts that happened in the past. Sending of thresholds disabled by default, you need to enable it in your icinga2 graphite.conf:
host = "127.0.0.1"
port = 2003
enable_send_thresholds = true
Metadata
Icinga2 can send metadata information about every host and service check. These data include information about downtimes, acknowledgements, states, execution time, latency and more. Sending metadata is disabled by default. To enable it, configure graphite.conf:
host = "127.0.0.1"
port = 2003
enable_send_metadata = true
