System & Docker Monitoring
A simple overview of the most important Docker host and container metrics.
The System & Docker Monitoring dashboard uses the prometheus data source to create a Grafana dashboard with the gauge, stat, table and timeseries panels.
RevisionDescriptionCreated
Docker
Docker
by Grafana Labs
Grafana Labs solution
Easily monitor Docker with Grafana Cloud's out-of-the-box monitoring solution.
Sign up for Grafana Cloud
Create free account
2
Import the dashboard template
Datasource
Dependencies
