Polkadot and parachains full monitoring
All in one monitoring for Substrate based Relay chain, Parachains and backups
Polkadot and parachains full monitoring screenshot 1
Polkadot and parachains full monitoring screenshot 2
Polkadot and parachains full monitoring screenshot 3
Full integrated dashboard for Substrate blockchains including Polkadot, Kusama and any parachain. If you use it, please add a review that will help improve it! Deployment guide: https://medium.com/bld-nodes/monitoring-multiple-substrate-nodes-polkadot-kusama-parachains-2022-2eb85cdf2533
Stack
  • Dedicated monitoring instance: Prometheus + Grafana + Node exporter (reverse proxy to DNS is advised)
  • Nodes: substrate node + node exporter
  • Communication: for a secure and light connection, Wireguard VPN is recommended. But a reverse proxy can also be used if you prefer this solution.
Prometheus config
yml config file has to meet the following requirements:
  • job_name: "prometheus" and job_name: "node_exporter" for monitoring local host
  • job_name: "mainnet" for all mainnet instances (validators, collators)
  • job_name: "backup" for all backups
  • for each instance, targets to the substrate & the node exporter metric endpoint + label chain with the chain name (the name that will be displayed in the dashboard' A template is available here
Contact
I love my work to be useful for everyone, please feel free to send me any comment or feedback:
If you’d like to tip or nominate my validators:
  • DOT validator: 12bLdVAgWiKHgFHtAaQstasMUWVq35oG9iwHCwsKoFFNoNrk
  • KSM validator: Hf8C626KBAjitMV7w8AhQWDCiPgUU47htEwbomq5mDMKeyL
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
