IBM Workload Automation Grafana Dashboard for Kubernetes environments 9.5 FP4
Visualize Workload Automation and related Kubernetes metrics
IBM Workload Automation Performance Dashboard
Overview
IBM Workload Automation uses Grafana to display performance data related to the product. This data includes metrics related to the server and console application servers (WebSphere Application Server Liberty Base), your workload, your workstations, critical jobs, message queues, the database connection status, and more. Metrics provide insight into the state, health, and performance of your deployments and infrastructure. IBM Workload Automation cloud metric monitoring uses an opensource Cloud Native Computing Foundation (CNCF) project called Prometheus. It is particularly useful for collecting time series data that can be easily queried.
Metrics
For more information see our Documentation
Workload
Internal Message Queues
Workstation Status
Liberty
Note: Version 9.5, Fix Pack 4 is required to enable the following monitoring features:
- Critical Jobs metric
- Workstation status metric
- Database connection status metric
- Job, Job stream, and Workstation Filters
Earlier versions of the product enable only a subset of the monitoring features available with Version 9.5, Fix Pack 4.
This Dashboard is licensed under Apache 2.0 license.
IBM DB2
Easily monitor your deployment of IBM DB2, a relational database management system designed to store, manage, and retrieve data efficiently, with Grafana Cloud's out-of-the-box monitoring solution.
