System Dashboard (Telegraf + Netdata)
InfluxDB dashboards for telegraf metrics + netdata Pressure Stall Information
System Dashboard (Telegraf + Netdata) screenshot 1
System Dashboard: Telegraf + Netdata
Based on https://grafana.com/grafana/dashboards/928, with tweaks.
The first page is a condensed system summary, including:
  • CPU usage by core in single graph
  • Memory usage (using the Committed_AS and Available values, which are more useful for overviews)
  • Disk I/O for all disks in a single graph
  • Network usage
  • Linux Pressure Stall Information (PSI), collected by Netdata
Tweaks to the original dashboard:
The influxdb datasource variables $telegraf and $netdata are hidden by default. To change them after importing the dashboard, open the dashboard settings, go to the variables section, click on the variable, change the "hide" selection box to the empty value, and click update. When you return to the dashboard, the variable will be modifiable at the top of the dashboard next to the other variables.
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
