JMeter Load Test
Dashboard
This dashboard shows live load test metrics provided by JMeter.
Last updated: 5 years ago
Start with Grafana Cloud and the new FREE tier. Includes 10K series Prometheus or Graphite Metrics and 50gb Loki Logs
Reviews: 5
JMeter Load Test Dashboard
This dashboard shows the main metrics gathered during a load test execution with JMeter. This dashboards depends on the JMeter-InfluxBD-Writer plugin for JMeter, that writes live load test data to an influxDB installation.
Prerequisites
Setting up JMeter
  1. Download the JMeter-InfluxBD-Writer and paste the jar into the /lib/ext directory of your JMeter installation. (Then Restart JMeter)
  2. In your JMeter load script add a Backend Listener node (Add -> Listener -> Backend Listener)
  3. Select JMeterInfluxDBBackendListenerClient for the Backend Listener implementation option
  4. Provide in the Parameters table your influxDB settings, provide a name for the test, and specify which samplers to record.
Get this dashboard:
1152
