Easy RabbitMQ (K8S)
RabbitMQ stats (easy to use in kubernetes)
Easy RabbitMQ (K8S) screenshot 1
Easy RabbitMQ (K8S) screenshot 2
This dashboard is Inspired by the official dashboard from https://next.rabbitmq.com/prometheus.html
It consumes a prometheus datasource.
The user can switch from multiple instances of rabbitmq.
It has been designed it to be used for monitoring multiple rabbitmq (installed using helm) running on kubernetes.
When installing rabbitmq on a k8s cluster:
$ helm install stable/rabbitmq -f values.yaml ....
don't forget to add this in values.yaml to enable metrics
metrics:
  enabled: true
RevisionDescriptionCreated
RabbitMQ
RabbitMQ
by Grafana Labs
Grafana Labs solution
Easily monitor RabbitMQ, the most widely deployed open source message broker, with Grafana Cloud's out-of-the-box monitoring solution.
Import the dashboard template
Datasource
Dependencies
