Hybrid performance with k6 browser
An alternative approach to browser-based load testing that’s much less resource-intensive is combining a small number of virtual users for a browser test with a large number of virtual users for a protocol-level test.
You can achieve hybrid performance in multiple ways, often by using different tools. To simplify the developer experience, you can combine k6 browser with core k6 features to write hybrid tests in a single script.
Browser and HTTP test
The code below shows an example of combining a browser and HTTP test in a single script. While the script exposes the backend to the typical load, it also checks the frontend for any unexpected issues. It also defines thresholds to check both HTTP and browser metrics against pre-defined SLOs.
JavaScript
import http from 'k6/http';
import { check } from 'k6';
import { browser } from 'k6/experimental/browser';
const BASE_URL = __ENV.BASE_URL;
export const options = {
  scenarios: {
    load: {
      exec: 'getPizza',
      executor: 'ramping-vus',
      stages: [
        { duration: '5s', target: 5 },
        { duration: '10s', target: 5 },
        { duration: '5s', target: 0 },
      startTime: '10s',
    browser: {
      exec: 'checkFrontend',
      executor: 'constant-vus',
      vus: 1,
      duration: '30s',
      options: {
        browser: {
          type: 'chromium',
  thresholds: {
    http_req_failed: ['rate<0.01'],
    http_req_duration: ['p(95)<500', 'p(99)<1000'],
    browser_web_vital_fcp: ['p(95) < 1000'],
    browser_web_vital_lcp: ['p(95) < 2000'],
export function getPizza() {
  let restrictions = {
    maxCaloriesPerSlice: 500,
    mustBeVegetarian: false,
    excludedIngredients: ['pepperoni'],
    excludedTools: ['knife'],
    maxNumberOfToppings: 6,
    minNumberOfToppings: 2,
  let res = http.post(`${BASE_URL}/api/pizza`, JSON.stringify(restrictions), {
    headers: {
      'Content-Type': 'application/json',
      'X-User-ID': customers[Math.floor(Math.random() * customers.length)],
  check(res, {
    'status is 200': (res) => res.status === 200,
export async function checkFrontend() {
  const page = browser.newPage();
  try {
    await page.goto(BASE_URL);
    check(page, {
      header: page.locator('h1').textContent() == 'Looking to break out of your pizza routine?',
    await page.locator('//button[. = "Pizza, Please!"]').click();
    page.waitForTimeout(500);
    page.screenshot({ path: `screenshots/${__ITER}.png` });
    check(page, {
      recommendation: page.locator('div#recommendations').textContent() != '',
  } finally {
    page.close();
Browser and failure injection test
You can also run a browser test together with a failure injection test by using the xk6-disruptor extension. This approach lets you find issues in your front end if any services it depends on are suddenly injected with failures, such as delays or server errors.
The following code shows an example of how to introduce faults to a Kubernetes service. At the same time, the browser scenario runs to ensure the frontend application is free of any unexpected errors that may not have been handled properly.
To find out more information about injecting faults to your service, check out the Get started with xk6-disruptor guide.
JavaScript
  scenarios: {
    disrupt: {
      executor: 'shared-iterations',
      iterations: 1,
      vus: 1,
      exec: 'disrupt',
    browser: {
      vus: 1,
      duration: '10s',
      startTime: '10s',
      exec: 'browser',
      options: {
        browser: {
          type: 'chromium',
  thresholds: {
// Add faults to the service by introducing a delay of 1s and 503 errors to 10% of the requests.
const fault = {
  averageDelay: '1000ms',
  errorRate: 0.1,
  errorCode: 503,
export function disrupt() {
  const disruptor = new ServiceDisruptor('pizza-info', 'pizza-ns');
  const targets = disruptor.targets();
  if (targets.length == 0) {
    throw new Error('expected list to have one target');
  disruptor.injectHTTPFaults(fault, '20s');
  try {
    check(page, {
    check(page, {
  } finally {
    page.close();
  • Start small. Start with a small number of browser-based virtual users. A good starting point is to have 10% virtual users or less to monitor the user experience for your end-users, while the script emulates around 90% of traffic from the protocol level.
  • Combine browser test with different load testing types. To fully understand the impact of different traffic patterns on your end-user experience, experiment with running your browser test with different load testing types.
  • Focus on high-risk user journeys as a start. Identify the high-risk user journeys first so you can start monitoring the web performance metrics for them while your backend applications are being exposed to high traffic or service faults.
