Plugins ใ€‰Salesforce
Developer
Grafana Labs
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
grafana
Enterprise
Salesforce
Documentation โ†’
Instantly visualize Salesforce data in Grafana
The Salesforce data source plugin is the easiest way to pull Salesforce data directly into Grafana dashboards.
  • Visualize it either in isolation (one database) or blend it with other data sources.
  • Discover correlations and covariances across all your data in minutes.
Installing Salesforce on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Salesforce from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v1.7.14 - 2025-08-13
  • โš™๏ธ Chore: bump version
v1.7.13 - 2025-08-12
  • ๐Ÿ› Fix: Fixed issue of query editor freezing when large amount of entities
v1.7.12 - 2025-02-17
  • โš™๏ธ Chore: Improve error logging
v1.7.11 - 2025-02-17
v1.7.10 - 2025-02-11
  • โš™๏ธ Chore: Update backend dependencies
v1.7.9 - 2025-02-04
  • โš™๏ธ Chore: Update frontend dependencies
v1.7.8 - 2025-01-10
v1.7.7 - 2024-12-18
v1.7.6 - 2024-12-16
v1.7.5 - 2024-11-22
  • โš™๏ธ Chore: Update dependencies
v1.7.4 - 2024-11-12
  • โš™๏ธ Chore: Updated backend dependencies
v1.7.3 - 2024-10-03
  • โš™๏ธ Chore: Minimal supported Grafana version is now 10.4.8
v1.7.2 - 2024-09-23
v1.7.1 - 2024-08-30
  • โš™๏ธ Chore: update backend dependencies
v1.7.0 - 2024-07-15
  • โš™๏ธ Chore: Capture error source
v1.6.0 - 2024-06-14
  • โš™๏ธ Chore: Added SLO metrics to the plugin
v1.5.0 - 2024-06-05
v1.4.0 - 2024-03-14
v1.3.3 - 2024-03-13
  • โš™๏ธ Chore: Backend binaries are now compiled with Go version 1.22.1
v1.3.2 - 2024-02-29
  • ๐Ÿ› Fix: 401 Authentication error
v1.3.1 - 2023-11-08
  • ๐Ÿ› Fix: Fix for broken JWT authentication. Previously instances with JWT authentication were failing with invalid_grant error
v1.3.0 - 2023-11-06
  • โš™๏ธ Chore: Minimal supported Grafana version is now 9.5.13
  • โš™๏ธ Chore: Frontend dependencies updated
  • โš™๏ธ Chore: Backend dependencies updated
  • ๐Ÿ› Fix: Updated display name for the results column
v1.2.0 - 2023-08-21
  • โš™๏ธ Chore: Plugin now explicitly sets the min TLS required version to tls 1.2
v1.1.2 - 2023-06-28
  • โš™๏ธ Chore: move to community maintained version of jwt-go
v1.1.1 - 2023-06-08
  • โš™๏ธ Chore: backend libs updated with golang:1.20.5
v1.1.0 - 2023-05-18
v1.0.11 - 2023-05-16
  • ๐Ÿ› Fix: (Config Editor) Fixed a minor UI bug where fields are not stored correctly when used with JWT auth
  • ๐Ÿ› Fix: (Config Editor) Fixed a minor UI bug where download certificate button wasn't working correctly when used with the JWT auth
v1.0.10 - 2023-05-04
  • โš™๏ธ Chore: Backend binaries compiled with latest go version 1.20.4
  • โš™๏ธ Chore: Grafana plugin SDK (grafana/grafana-plugin-sdk-go) updated from v0.159.0 to v0.161.0
v1.0.9 - 2023-04-17
  • โš™๏ธ Chore: Backend binaries compiled with latest go version 1.20.3
v1.0.8 - 2023-03-19
  • Config Editor - Improved healthcheck error messages
v1.0.7 - 2023-02-28
  • โš™๏ธ Chore: Backend binaries compiled with latest go version 1.19.6
  • ๐Ÿ› Fix: (Config Editor) Fixed a bug where editors were incorrectly determining auth type when used with provisioning
v1.0.6 - 2022-11-02
  • โš™๏ธ Chore: Backend binaries compiled with latest go version 1.19.4
  • โš™๏ธ Chore: Backend Grafana dependencies updated to latest version
v1.0.5 - 2022-11-02
  • โš™๏ธ Chore: Backend binaries compiled with latest go version 1.19.3
v1.0.4 - 2022-10-28
  • โš™๏ธ Chore: Backend binaries compiled with latest go version 1.19.2
  • โš™๏ธ Chore: Backend grafana plugin SDK updated to latest
  • โš™๏ธ Chore: Frontend grafana dependencies updated
  • โš™๏ธ Chore: Minimum required grafana runtime updated to 8.4.7
  • ๐Ÿ“ Documentation: Typo errors fixed
v1.0.3 - 2022-03-02
  • ๐Ÿ› Fix: Ensure http connections are reused
v1.0.2 - 2022-02-25
  • ๐Ÿ› Fix: Ensure http connections are closed
v1.0.1 - 2022-01-07
  • โš™๏ธ Chore: Individual License Check
v1.0.0 - 2021-09-09
  • Support JWT Authentication
v0.12.0 - 2021-08-18
  • Reports
v0.11.0 - 2021-08-06
  • SOQL Builder
v0.10.0 - 2021-07-30
  • Fixed a bug where incorrect auth URL used for non sandbox accounts.
  • In config, Password and Security token now captured separately.
  • Improved error messages in healthcheck config
v0.9.3 - 2021-07-08
  • ๐Ÿš€ Feature: Macros for Quarter Start/End
v0.9.2 - 2021-06-23
  • ๐Ÿ› Fix: Parent-to-child (one to many) relationship queries
v0.9.1 - 2021-06-16
  • ๐Ÿš€ Feature: Query Editor Suggestions
v0.9.0 - 2021-06-07
  • Beta release
