Plugins
PanelCommunity
Business Variable logo
Business Variable
Grafana Labs
Get plugin
Business Variable for Grafana
Marketplace Downloads CI CD License
This project was originally contributed by Volkov Labs — thanks for all your great work!
We have republished under the same plugin ID, keeping the community signature. This means you can simply update your plugin version. A new ID would have required manual updates to your dashboards. For additional information on the changes, see the Notices.
This project is currently maintained by Grafana Labs. We welcome pull requests and will review them on a best-effort basis. If you're interested in taking on this project long-term, contact integrations@grafana.com. We're eager to work with new maintainers and eventually hand over the project.
Business Variable transforms how you interact with Grafana dashboard variables. Place it anywhere on your dashboard and choose from multiple layouts, including an advanced TreeView option, to simplify filtering and boost usability.
🚀 Key Features
  • Display Modes: Choose from Table, Minimize, Button, or Slider layouts.
  • TreeView: Hierarchical data visualization within Table mode for complex nested variables.
  • Thresholds: Highlight statuses using data source thresholds for visual clarity.
  • Variable Support: Handle single or multi-value variables with an "All" option.
  • Filtering: Apply pattern-based or favorite-based value filtering to quickly find options.
  • Sticky Positioning: Panel follows scrolling for easy access across long dashboards.
  • Tabbed TreeViews: Organize multiple TreeViews into groups or tabs for better organization.
  • Input Box: Support for text input variables with custom validation.
  • Responsive Design: Adapts seamlessly to different screen sizes and panel dimensions.
  • Theming: Fully compatible with Grafana's light and dark themes.
📋 Requirements
Plugin Version Compatible Grafana Versions
Business Variable 5.2+ Grafana 12.3 or later
Business Variable 5.0–5.1 Grafana 11.5 or 12
Business Variable 4.x Grafana 11 or 12
Business Variable 3.x Grafana 10.3 or 11
Business Variable 1.x/2.x Grafana 9.2 or 10
🛠️ Installation
Install the Business Variable panel through the Grafana Plugins Catalog or using the Grafana CLI:
grafana-cli plugins install volkovlabs-variable-panel
After installation, restart Grafana and add the Business Variable panel to your dashboard.
📚 Documentation
Dive into detailed guides to make the most of Business Variable:
Section Description
Data flow Understand the panel's data flow
Display mode Explore layout customization options
Features Learn about key capabilities
Release notes Stay updated with recent changes
📜 License
This project is licensed under the Apache License 2.0.
Insights
  • Adoption
    Running on 38,055 active Grafana instances.
  • Activity
    Last updated 22 May 2026.
    3 releases in the past year.
Version
5.2.0
Dependencies
  • Grafana >=12.3.0
Developer
Grafana Labs
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
